My camera takes several seconds after each photograph before you can take another photo... it used to be really fast. What wierd setting did we turn on that now causes this delay?
This can happen when the card is nearly full or you've been deleting the pics but never formatting the card to give it a fresh start. Download any pics from the card and then format it in the camera.
One of the flaws of Point and Shoot cameras is the delay to take photos. In general you can reduce this time as follows:
Set up camera and hold it still frame the photo and press the shutter half way. If it can FOCUS (green rectangle) then all is GOOD. I will call this ready mode.
When the moment you want to photograph arrives, with a ready camera, you press the shutter all the way. The photo is taken quickly. There is a delay to DISPLAY it.
use high quality speed card. secondly every camera company shows you bright picture because they want to cell their product with bright screen. so if you are a photographer then you ahve to use screen brightness and darkness in camera keep it on -2 setting
STEP-BY-STEP INSTRUCTIONS FOR OPERATING YOUR FIRST DIGITAL CAMERA 1. READ YOUR CAMERA MANUAL before taking any photographs. 2. Check your batteries. Make sure to either recharge or replace them if you haven't used your camera as yet or for an extended period. 3. Insert your storage media card in the appropriate slot. If you forget to insert your media card, you'll get a "No Card" message. 4. Remove the lens cap. 5. Turn the camera on by either an on-off switch or a sliding lens cover. 6. Turn off the LCD. (See your camera manual for instructions) 7. Make sure your camera is set for automatic mode. Set the image quality to the size image desired-HQ (high quality) or less (to take more pictures on the same card). 8. Bring the camera up to your eye and look through the viewfinder. Positioning the target mark in the center of the viewfinder on your subject will assure that it will be in focus. 9. Push the zoom lever toward W (wide angle) to shoot wide-angle shots or push it toward the T (telephoto) to zoom in. 10. Press the shutter button half way down gently and confirm that the green light next to the viewfinder is illuminated. 11. Press the shutter button all the way down. You'll hear a beep when you take a picture. Wait until the green light stops flashing before taking another one. Remember, digital cameras have a slight delay that traditional cameras don't since it takes a second to save the image to your camera's storage media card. 12. Turn off the camera. Your new photograph should appear on your camera's LCD screen. TIPS: 1. Use the viewfinder to compose your photograph, not the LCD screen, which will severely drain your battery power. Use your LCD screen only when shooting close-up photographs. 2. Hold your camera steady. Sometimes, the least amount of movement will cause your photo to be slightly blurred. Purchase a very small tripod so that you can provide extra stability for your camera. Also, if there isn't enough light (indoors or outdoors), make sure to use your camera's flash. 3. Experiment with your camera's features and take notes so that you can learn what works for you. Do this before you plan to use it for an important family event or trip.
the delay of producing pictures might be caused by these conditions: -the active d-lightning option is turned on -the noise redution option is turned on -the camera has been used to take more than 100,000 shots
the mirror in DSLR has it`s own lifecycle, normally they will unstable after 100,000 shots cycle and it is very normal
Without seeing the image, it's difficult to pinpoint the problem. But, going on the description you've described here, my guess would be that your shutter speed is too low to record any movement sharply, or is recording movement you are making while holding the camera. Some things that you may want to review with the camera to ensure that you're shooting the images correctly:
First, if you can look at the image using a photo editing program, see if you can review the EXIF (also called metadata) file and look at the exposure. Generally, anything under 1/30th of a second will show motion blur introduced from hand-holding the camera. If the shutter speed is below this, you should consider using a higher ISO setting or opening the apperture (this equates to a lower "F" number, so "F4" allows in LESS light than "F2.8") to allow more light into the lens. Remember that doubling the ISO will allow you to make an exposure with HALF the light. The down side to this is that higher ISO settings, particularly in Point and Shoot cameras, introduce higher levels of noise.
Ensure that you are no more than 10 feet from your subject. Most on-camera flash units are much less effective beyond this distance.
If you are photographing sports/action, remember that a shutter speed of 1/250th of a second will eliminate most motion blur.
Also remember that most point and shoot digital cameras are "one chip" cameras and often have multiple tasks to perform while making an image (focus, exposure, flash, recording and writing the file are all performed at the same time...), so it's not uncommon to see delays (also called "shutter lag") in point and shoot cameras (DSLR's have multiple chips, and don't have this issue...). One way to resolve this is to depress the shutter release half way. This keeps the chip "hot" and ready to expose. Doing this with a point and shoot camera greatly increases the responsiveness to the shutter release.
hello again after researching i did find out that there is about a 3 second delay if using the flash option did any of your delays happen when not using the flash ? also does this happen when using the camera in auto mode ? turning the knob on the top to the green auto mode i'm thinking it also could have to do with your shutter speed or try going to the menu and changing the shutter speed to a faster speed your self then taking pictures in av or tv mode. here's a comment from a review on the PowerShot a590 that might help.
Camera performance is very good. The PowerShot A590 is ready to shoot after a 1.2 second delay -- pretty snappy. Focus speeds were very good, even in low light situations. Shutter lag wasn't a problem, and shot-to-shot delays were minimal, except when you're using the flash, which is slow to charge. The camera can shoot continuously at 1.5 frames/second until your (high speed) memory card is full. The A590's battery life is 10% better than its predecessors, and is well above average for its class. The camera supports the USB 2.0 High Speed standard, for fast data transfer to a Mac or PC.
and if you still have the problem with out the flash then the only other solution is a faster flash memory card there's cards made just for digital camera's that store pictures and format quicker.
hope this helps your enjoy your camera.
Are you sure you aren't in the delay setting in drive mode? This camera has 2 delay settings, one for 2 seconds between when you press the shutter and when it takes the photo, and one with 10 seconds delay - often used when you want to be in the photo (e.g. self-portrait or group photo).
If you aren't in the delay mode, then I need to know more about your settings. What shooting mode are you using? What type of photo are you trying to take (portrait, landscape, sports)? Are you shooting indoors, outdoors, bright sunlight, overcast, etc.?
The delay is absolutely normal. When you press the button to take a picture, the camera takes its 1-3 seconds to focus on the image, prepare the flash. Once that's done, the camera "clicks" and the photograph is taken.
