Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
The 03 error code is the drain. Disconnect the drain hoses and
check for blockages, look for block at end of exit hose. If no blockage "time" the drain interval. If
it's more than 6 minutes it's the pump. Also make sure you're using the correct
type of soap so the ball check valve on the bottom of the outer drum isn't
getting fouled with excessive suds. Also disconnect the drain hose from your
house plumbing and let it free flow on it's own. This will tell you if the
blockage is in your plumbing and not in the machine.
Pl rate me ‘very helpful’ for the free help!
