Sony VAIO A250 Notebook Logo
Posted on Jan 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The screen on my Sony Vaio VGN A250 model PCG 8R7L is showing enterference is there a service manual from Sony for the Sony Vaio VGN A250 model PCG 8R7L I can obtain?
DNA Computing!!!
Level 2:
  • Expert 304 Answers
  • Posted on Sep 08, 2010
DNA Computing!!!
Expert
Level 2:
Answers
304
Questions
0
Helped
91172
Points
728
Hi kyle662919.
You may download the Service Manual from the below link:
http://home.comcast.net/~nw_systems/vgnA.pdf
Please open the above link to download the Service Manual for the VGN-A200 Series Notebooks.
Hope this helps.
Please feel free to contact for further assistance.
Vaio vgn a250 saying that original battery is not genuine sony
This is because you didn't install the Sony Share Library or Sony Firmware Extension Parser.
As a work around you can disable the pop up with the following steps:
1) Click on Start
2) Click on Run
3) Type "MSCONFIG"
4) Press Enter
5) Click on the Startup tab
6) Scroll down and locate ISButility
6) uncheck it
7) Restart the PC
We Are Here To Help!!
Donald Deane MCSE,ASE,CPO
Service Manual for Sony VAIO PCG-7184L
Try www.ebay.com Type make and model of laptop, refine search to screen or scroll through the list.
3helpful
HAVE TRIED CHANGE THE CMOS BATTEWHAT CAN I DO NXTRY TO REMOVE BIOS PASSWORD BUT IT COUDNT WORK,?
Sony Vaio PCG and some Vaio VGN Series use the last 7 digits of the laptop serial number to calculate the bios master password. The serial number for a Sony Vaio is often located on the bottom of the laptop on a white sticker. The serial number may also be found by removing the battery and checking in the battery compartment. The link to unlockbiosrecovery.com below works on the following models:
PCG-C, PCG-F, PCG-GR, PCG-GRS, PCG-GRT, PCG-GRV, PCG-GRX, PCG-GRZ, PCG-N, PCG-NV205, PCG-QR, PCG-R, PCG-SR, PCG-SRX, PCG-TR, PCG-V, PCG-VX, PCG-X, PCG-Z, VGN-B, VGN-FS, VGN-S, VGN-T, VGN-TX1, VGN-X
I use http://www.unlockbiosrecovery.com/Unlock_Sony_Bios.php
For $20 they use the last 7 digits of the laptop serial number to calculate the bios master password and then email it to you in an hour. They guarantee it to work and you can call them if you have a question.
1helpful
2answers
My vga card for sony vgn-t2xp model pcg-4d1m
The model of your sony vaio is VGN-T2XP/L and chassis type is PCG-4D1M
I can only give you a link where you can download necessary drivers, updates/firmwares or original drivers that comes with this unit. It depends on what operating system you are currently using.
If you then upgrade your operating system for example from windows vista to windows 7, then suddenly some hardware including sounds, lancard, vga experienced some troubles, I do suggest you downgrade again your operating system or find appropriate compatible drivers that will work for your new operating system.
In this link you will find something that might help you.
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-T2XP_L
Let me know.
10helpful
3answers
I NEED THE WEB SITE FOR A SONY MANUAL MODEL #PCG 81114l
http://www.docs.sony.com/release/PCGK30series.pdf
2answers
My sony vaio model pcg-7y1l is not working. When
i had the same prob this morning there are 3 things you can try
1 memery
2 proccessor
3 hard drive
if not any of them
try the dvd drive
if not that then try exsternal monitor if dont show on that then motherboard is gone
10helpful
5answers
Ethernet drivers for sony vgn-fs115m
Hey MIDO Try This Tool
VAIO Launcher 1.4.11 Update Program
This program will update VAIO Launcher pre-installed on the VAIO model listed below.
VGN-S4HP/B
VGN-S4HRP/B
VGN-S4M/S
VGN-S4XRP/B
VGN-S4Z/S
VGC-V3S
VGC-V3M
VGN-FS285H
VGN-A497XP
VGN-A417M
VGN-A417S
VGN-FS295XP
VGN-FS215Z
VGN-FS215M
VGN-FS295VP
VGN-FS215B
VGN-FS215E
VGN-FS215SR
VGN-FS215MR
VGN-FS285M
VGN-FS285B
VGN-FS285E
VGN-FS215S
VGN-B3XP
VGN-B3VP
VGN-S4XP/B
VGN-S4VP/B
PCG-K415S
PCG-K415B
VGN-FS195XP
VGN-FS195VP
VGN-FS115S
VGN-FS115Z
VGN-FS115M
VGN-FS115E
VGN-FS115B
VGN-FS115ZR
VGN-FS115M -- ( Thats Ur MODEL)
VGN-A397XP
VGN-A317S
VGN-A317M
VGN-S3XP
VGN-T2XP/L
VGN-T2XP/S
VGN-T2XRP/S
VGN-S3VP
VGN-S3HP
VGC-RA304
VGC-RA204
PCV-RS704
PCV-RS702
VGC-M1
VGC-V2S
VGC-V2M
VGN-T1XP/L
VGN-T1XP/T
VGN-B1XP
VGN-B1VP
VGN-S2XP
VGN-S2VP
VGN-S2HP
VGN-S2XRP
VGN-S2HRP
VGN-A297XP
VGN-A295HP
VGN-A217S
VGN-A217M
VGN-A215M
VGN-A215Z
PCG-K315Z
PCG-K315S
PCG-K315B
PCG-K315M
This update resolves the problem of registered applications not launching from the VAIO Launcher toolbar.
Note: This program requires VAIO Zone 1.2.05 or later. If your VAIO model comes with VAIO Zone 1.2.02, you must first update VAIO Zone before running this program.
Download and installation
1. Download the file SOAVZN-01028300-UN.exe and save it to a download directory
2. Close all running applications
3. Go to the download directory and double-click SOAVZN-01028300-UN.exe
4. The InstallShield wizard starts
5. Click Next and wait while setup is installing the new software
6. Click Finish when the installation is complete
HERE
2answers
Sony Viao Display Problem
Sounds like you have some internal issues going on with this Laptop! If you are getting the same response when you connect an external monitor, then you more than likely have a few things going on here: A bad VGA port for starters, Issues with the Data card, and your graphic card is cetainly not helping. In addition you may want to check appropriate drivers as they are sometimes updated! But my best guess is that you are having issues internally! That could be costly! Sorry!
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
