no full model told , letters at end of 5101 (matter huge)
moved you out of HP forum to acer and guessed mode. above.
so forgot to ask directly Acer.com this.
ask for the CPU QVL list, means CPU qualified vendors list.
they have nO LIST, it is not a gaming PC so nobody plays musical CPU there. (and gains are nill)
the answer is always this, if you read the top web site cpu upgrades
1: it must have socket, there, vast laptops do not , all now.
yours does. and pin counts correct.
2: the BIOS must like it;. or upgrade bios I acer told you it has newer CPUs added, and OMG a list.
3: the chip set inside AMD must allow it; (pure cold logic)
4: new CPU does not violate mobo power VRM ratings for watts.
not cause PC to overheat, easy as most laptops love to do.
5: the bios allows new clocking .
6: the mobo bandwidth allows it, going faster clocks
these rules are only a base line, CPU are not like light bulbs.
new it had this,
2 GHz AMD Turion 64 X2 Mobile
638-pin lidless micro-PGA
called s1g4 is the fourth and the last revision of socket S1. The S1g4 was employed exclusively by mobile AMD microprocessors from 2010 mainstream platform, codenamed Danube
the list is here
https://www.cpu-world.com/Sockets/Socket_S1_(S1g4).htmlonly acer.com can answer which in the S1g4 .
them only OR BUY AND TRY WASH WEAR AND REPEAT.
YOU TELL US.
good luck.
Ps :
THIS VERSION IS.
https://www.userbenchmark.com/System/Acer-Aspire-Z5101/22608
YOURS IS NOT there. IN THE 1 MILLION pc THERE.
means nobody does this just you
Thank You For Your Help SirHanz. I have been to that web page before. I was hoping somebody has done this in the past. I see it lists those processors, But I took it as those were the cpu's that came as options in this package. I thought it looked like a socket 7. I tried to access the bios with the f2 key and it just keeps booting up to windows. I will keep trying though. Thank You Again For Your Time, You were Helpful!
