The manual doesn't tell me anything about that blinking red light at the icemaker on/off switch. It's not producing ice, the water line isn't frozen, the freezer is good and cold, there is no ice jammed in the storage bin or dispenser parts. Help! We didn't recently remove a lot of ice the ice make just stopped working. Water works in door freezer is the right temperature what is an easy fix for this?
Take off the bottom black cover. flip it so that you are looking at the insideof this piece. Within the little cracks there are additional manuals including how to test the lite panel on ice maker. this piece of paper is a creame color.
You have a better chance of finding out that the problem is a broken moduele. The fingers that grab the ice and rotate it out they should be resting at the 2 oclock posotion. If stuck in any other posotion its broken. It's expensive but not hard to do. If you had a bad soloniod you would either have a frozen tube or a block of ice at the top
This light is flashing because the door is open and the ice maker beam is blocked. When you close the door (or simulate closing the door by pushing back the plastic sensor that is blocking the beam), the light will stop flashing. So turning the switch on and off is not the issue. It is likely a blocked line or an solenoid thread.
Try flipping the switch i think that light should be green
I have the same problem. The ice maker isn't making ice and the red light is flashing. I can't find an explanation.
I have the same problem, no ice is being made, water is working, nothing
is clogged or frozen?
posted by disder2000 on Feb 13, 2008
Report abuse
Everything disder2000 posted is exactly my problem.
same problem
We, too, are having exactly the same problem as 'disder2000'. Tomorrow morning we will call for service to at least isolate the problem, then decide whether we do it ourselves or hire it out. Will check back for more suggestions and will add a repair comment when complete. Thanks!
icemaker is not producing ice
did anyone ever find out what was causing the ice make to
stop producing ice??
I have the same problem and would love to know the fix. Thanks.
Same exact problem here too. ????? any thoughts?
