Check AC Adapter for voltage output using multi-meter. If Adapter is GOOD, remove battery and try again. Does fan run? Does screen show Flash Screen? Please advise in detail.
most likely a loose connection if it is flickering.. if there are red squiggly lines usually means driver issue.. and if there are blue banding lines, typically means the chip is overheating/desoldering.
Mi tv lcd es marca LG modelo 32LD330, al encenderlo se escucha y cambia de canal pero el video lo emite a mitad no da la imagen completa que puede ser?
