Hello there:
F3 - E1
Oven temperature
sensor shorted
Replace oven
temperature sensor
Now if it is just a f-3 and nothing else3
f 3
Open oven
temperature sensor or thermal fuse
Replace oven
An f3 error code is an open temp sensor error the problem could be in your temp sensor or your ERC. If you unplug the appliance and remove the two screws holding in your temp sensor there will be a clip. Remove the clip and ohm the temp sensor if you get a reading of approx 1100 ohms at room temp then the problem is in your control board.
