Computers & Internet Logo
Anonymous Posted on Jan 22, 2010
J71c (sylvania f70 monitor). I don't have instructions on how to adjust the screen features and I cant find them anywhere on the web. Thank you. Ed.
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Jan 22, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
1639
Points
24
Http://www.retrevo.com/s/Sylvania-F70-Monitors-review-manual/id/23240ci673/t/1-2/
hope it helps XD
Testimonial: "Thanks for the help. I appreciate it. Even though I didn't find the exact manual, I found one that was similar. Thanks again, Ed."
Screen shifted to the left
boot in (safe mode) Hold F8 when restart in safe mode right click anywhere on desktop change display mode
Should work
gl the ed
3helpful
2answers
Brightness of my desktop has been increased what to do??
I've recently come to the realization that my computer monitor screen is not properly calibrated. In different web forums where photos are posted, I'm noticing that I can't make out a lot of the pictures people are talking about - they're too dark. I've also noticed this when printing out CD covers - detail in the shadows that I never saw on the screen. Also, every time I show people digital photos, I have to turn up the brightness (in Photoshop) to anywhere between 25 - 50 %! Needless to say, I need to calibrate my monitor. For a test, I downloaded one of those "black level" graphs whrere the squares go from dark to light and you should be able to see every square clearly - I can only see half before they disappear into all blackness.
I have one of those old "turn of the century" big Dell Monitors that came with my original computer back in 2000. It has two "select" buttons (- +) and two "adjust" buttons (- +) with a row of icons (showing which parameter you're adjusting) with lights underneath on the left. I know that the "sun" icon is brightness and the "half moon" icon is contrast, but I don't know what the rest are.
After selecting "brightness," I hit the adjust "+" button a couple of times and I expected to see a bar graph showing my adjustment, but there was nothing, so I left it alone. I don't want to screw up my monitor so I want to make sure that I'm doing this right. It says "recall" under the select and adjust buttons with "arrows" pointing to two buttons. I assume that you press these to go back to your default settings.
So, how do I go about doing this correctly? __________________
Paul
1helpful
2answers
My auto wrnch belt broke - I need a replacement so I can fix it. I cannot find the part anywhere - is it available? Thanks, Ed
No they don't make any replacement parts for end users on this tool. You would have to take it to a service center for repair.
Cant get it off autolock feature
dear you press the menu button for 5 seconds then your auto adjust option will be released and you want to lock it again then press again menu button for 5 seconds then auto adjust option will again locked.
2answers
My monitor keeps saying auto adjustment in progress
Hello Friend,
This is automatically adjusting your Screen.Horizontal/vertical manual manual adjustment and Focus adjustment can Solve the Problem.Turn off auto feature. I hope your Problem can be Solved by going to this link for Detailed Instruction of your Monitor...
Thanks for Contacting FixYa...Keep Using..
Monitor width has changed ....cant see start and clock... even buttons on monitor for shape is not responding...
assuming wondows machine - anywhere on the desktop right click go to properties go to settings tab and adjust your screen resolution up.
Keep me posted.
1helpful
The auto-darken feature(monitor goes dark on dark
In your monitor panel you'll find 4 buttons. Press the menu button and get into Magic Bright. There you can choose the one that best suits you. You can even set to Dynamic contract where the monitor adjusts the brightness according to the elements on the screen
HP dv2660 Sp. Ed.
try right click anywhere on desktop go to properties/display settings
it should show 2 monitors you may have to plug 2nd monitor in and on there should be a box to tick for 2nd monitor hope this helps
2helpful
3answers
How do I get the widescreen monitor to show unstretched images?
i had the same problem with my new widescreen monitor... turns out the best setting (at least, for my specific monitor) was 1440 by 900 pixels. at this setting the desktop still stretches itself to fill the entire screen, but everything else is completely unstretched. (to adjust the screen resolution, right click anywhere on the desktop, then go to properties, then settings.)
Top Sylvania Computers & Internet Experts
Paul Bade
ADMIN Eric
ADMIN Eric
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
