When i charge the hfblu-lt200 bluetooth the red light stays on 15 mins do the bluetooth still be charging up when the red light goes off need to know this because i don`t know if it still charging or not
Um, I don't think that there are drivers for a bluetooth headset. It just needs to link (pair) with the other device, meaning the phone. It may be possible to update the firmware, if the headset has a data port (never seen one) and the mfg writes updates (I doubt it)
That usually means it isin pairing mode. Charging some headsets from extended periods can sometimes reset the device requiring you to pair the device again.
the problem seems to be the charging box. if the red light goes off relatively quickly after you place the bluetooth in the box then it is not gaining a charge. you have a warranty with this item that you can claim by following the instructions on the warranty card provided in the package.
make sure your bluetooth is in pairing mode. you know its in pairing mode when you see a red and blue light start to flash at the same time. you can achieve this by making sure the bluetooth is turned completely off then holding down the power button until you see BOTH lights start to flash.
yea same thing happen to me just for the past week at first it just didn't charge & lasted for 10 mins now it won't even flash MOTROLA U ****!!! I WANT REFUND FOR MY H550 Buetooth
For Cellular Innovations Mini Blue HFBLU-AX1C. To Pair with Your Phone....
1. Turn OFF Bluetooth Headset 2. With Headset within 1 Ft of your phone, hold down power key for about 8 seconds until indicator light blinks in red and blue color quickly (in pairing mode) 3. Search bluetooth device through your mobile phone. 4. Select HFBLU-AX1C in the bluetooth device list and enter the password 1234.
From the symptom it indicate that the bluetooth having charging problem.one thing you can do is to ensure the charge contact ( both charger & bluetooth ) is good ,mean you may need to do some cleanning.if still can't hold the charge then the battery in bluetooth may need to replace. hope it help.
