By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print
settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the
empty color cartridge because they are programmed to clean ALL the ink
nozzles. The only way to continue printing is to replace the empty ink
cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
SOURCE: can you make the brother mfc-490cw print in black
Yes, go to properties for the printer, probably right click on the printer under printers, click on "printer preferences", and then click on "color", and change it to print in "gray scale". This will be black only. This may not be the exact way to do it on your system but look for the color setting under the printer and change to gray scale.
SOURCE: I can't afford color ink
Hi, the problem is you cant, when the color ink has run out the printer will stop working and keep telling you their is no ink and it needs replacing, on older printers you use to be able to do this but on the more modern ones they stopped this so you had to use new inks all the time, their is no way round this problem, sorry
