Question about Microtek C593 15" Flat Panel LCD Monitor
I plugged the wrong voltage cord into the monitor, and now the correct cord doesn't work. Can it be fixed?
    Sniper:
  • 66 Answers
You may have shorted out the AC plug. You'll need to test it for continuity by using a voltmeter.
If it is shorted out, then you'll need to have the plug replaced.
Posted on Jan 21, 2010
Where do I plug the blue cord into a Dell desktop monitor circa 2006? I think the cord may be in the wrong place and I am struggling to remove it. If it is correct, then something else is wrong.
it is in the correct place..There are 2 little thumbscrews that are the same color blue and you cant tell they are screws use a flat head screwdriver and unscrew them. hope this helps
May 03, 2014 | Dell E173FP 17" LCD Flat Panel Monitor
Mysony wega KDP-57WS655 press power button straight to standby flashing 10 times
Indicates a problem with the high voltage circuit. You could try unplugging the power cord, plug it back in and try again. If that doesn't work unplug the power cord again but leave unplugged for at least five hours and try again. Still doesn't work find a local repair shop that works on sony tvs and have them fix it for you.
Mar 01, 2012 | Sony Grand WEGA KDP-57WS655 57" Rear...
Hp PSC1210 All-In-One not turning on
HP makes a couple of different power cords for the PSC 1210 and their other printers. First make sure you are using the correct power cord (Amperage and voltage). Unplug the power cord (from the wall and the printer and from a power module if you have one). Leave all of the sections unplugged for at least 15 seconds to reset the power module/printer.
Next connect the power cord to the wall outlet and to the power module if present and check if the LED (if present lights up). If it doesn't try another outlet. In either case, check what the outlet voltage/amperage is at the end of the power cord with a multimeter (before you plug it into the printer). If you have a power module, then check the Amperage (it will be a DC current out).
If you are not getting the correct voltage and amperage out or the LED doesn't light (with a known good outlet), try a different power cord/module.
You can order these from HP.
If you have the correct power at the cord, plug the power cord into the printer and attempt to turn it on. (Press and release the power button.) If the printer still doesn't come on, the unit needs service. Contact HP if the printer is under warranty. Decide if it is worth fixing if it is out of warranty.
I hope this helps.
(I've had to use the HP Repair/Replacement service after a unit was in a home that was hit by lightning. Due to printer availability, an HP gift card was provided to buy a new printer.)
Dec 11, 2011 | HP PSC 1210 All-In-One InkJet Printer
My new phone seem stuck on 'Phoine in use" which is clearly not, so I can't call out andcannont receive incoming calls - please help.
It's stuck because it doesn't see the proper voltage on the line. You either have the cords in the wrong place, low line voltage, or didn't follow setup instructions. Try looking to see if your base cord is not plugged in properly or if there's an instruction to start with or without batteries.
Carl
Aug 24, 2011 | AT&T Lands Phones
My monitor is unresponsive. Does not power on anymore. Does anyone have any troubleshooting ideas?
If your monitor uses a power supply (the brick that plugs into the wall, and then a smaller cord plugs into the monitor), then it's more likely the power supply that's gone out than the monitor itself.
Find someone with a multimeter to check the output voltage on the power supply. There will be a label on the power supply that says what the DC voltage (VDC) is supposed to be. If the meter shows no voltage when the power supply is plugged into the wall, then you just need a new power supply.
Do not try using another power supply as a substitute unless it is a specific match to your monitor. They vary widely by output voltage, etc. and using the wrong one could fry your monitor.
Hope that's helpful.
Jan 14, 2011 | Dell E207WFP LCD Monitor
Hi, I bought my samsung 2333 syncmaster in the U.S. but moved to New Zealand where the voltage is 230, can I use the monitor with a converter plug or with a NZ compatible cord?
Samsung 2333 have switching power supply and it can work from 100-240VAC 50/60Hz with out any modification or adaptors. Feel free to use it in USA or New Zealand. You need only to arrange plug converter. Check specifications on Page 49 of 2333SW user's manual available on: https://www.manualslib.com/manual/201694/Samsung-Syncmaster-2333sw.html?page=11#manual Samsung SyncMaster 2333SW User Manual Your Monitor Initial Settings
Jun 03, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
SIR, PLEASE GIV ME THE BEST SOLUTION FOR FOLLOWING PROBLEM WITH MY LENOVO 3000 Y410 LAPTOP (WITH XP AS O.S. ) ON MY EMAIL_ID=swatijadhav44@gmail.com AS EARLY AS POSSIBLE. SIR, MY LAPTOP SCREEN STAYS BLACK...
You can't even get into the BIOS. Hard drive failure?
Here's what the manual say's about black screen.
Verify that: The monitor cable is securely attached to the rear of the monitor and to the rear of the computer.
The monitor power cord is plugged into the monitor and into a working electrical outlet.
The monitor is turned on and the brightness and contrast controls are set correctly.
The voltage is set to the correct setting for your country.
The monitor signal cable is securely connected to the monitor and to the monitor connector on the computer
.Note: If your computer has two monitor connectors, verify that your monitor is connected to the one in the AGP option connector rather than the one in the rear of the system board.
If you can check the monitor by using another monitor.
I suspect hard drive failure. Keep me informed on what you tried and I'll keep checking to come up with solution.
Sep 23, 2009 | Lenovo 3000 Y410 Laptop
Dead Monitor
the monitor is dead
Jul 26, 2008 | Compaq V700 17" CRT Monitor
Gateway EV910B monitor power requirements
i dont think there is but there might be a switch inside the housing of the screen i would call gateway! it was sold with a 115v power cord so its proabaly factory set to use 115v you might however be able to change it? if you open the cover to the screen please make sure you know what you are doing TOUCHING THE WRONG THING CAN/WILL KILL YOU!!!!! please be careful :)
Jun 13, 2008 | Gateway EV910B Monitor
Microtek C593 15" Flat Panel LCD Monitor Logo
57 people viewed this question
Top Microtek Computers & Internet Experts
Thomas F. Schneider
William Miller
William Miller
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
