Main cause The laser driver/BD PCB is faulty (laser activation failure, BD detection fault). The DC controller PCB is faulty. The image processor PCB is faultly.
E100 0000 BD detection PCB failureThe BD detection PCB is faulty. - Check the connector of the BD detection PCB.- Replace the laser scanner unit.- Replace the DC controller PCB.
You can try to reconect the conectors on dc controler board, and on laser unit, clean the laser, check if the laser shuter is broken. If notthing helps the next step would be to chnage the laser unit and/or dc pcb
The most common cause for E100 is the drum unit. At the rear of the
drum unit should be a small peg pointing into the machine. This gets
broken off. It's purpose is to opperate a laser cut off shield when the
drum is removed so to prevent laser exposure. If peg is missing laser
will not be detected by the system and give E100. Can be repaired or
will require a new drum if it has done more than 40 to 60K copies.
