There should be a fan symbol on your remote control. In the "mode" control, there should be the following options.. Heat, cool, Auto and fan. If you select fan, only the fan will run. No heating or cooling.
When you set your thermostat to auto, it will automatically shut off when it reaches the temperature you set it at. I personally set mine on auto because I don’t want it to run constantly. This will save you money on your gas or electric bill. The blower will run constantly if you set your thermostat in the on position.
it is ok to run your fan continously. constant air filtering as long as it pauses before a/c cycles on. will not use any more electricity than a toaster. is there a fan programing feature on t-stat. if so you will need to turn programing to fan off
Is the air cold inside? You are talking about the fan inside? Have system check for freon but more than likely, it sounds like a t'stat problem. And it's not normal for the fan to run constantly.
