See the CL error and the door is indeed shut,
pull gently back on the door. if you hear a click and the unit starts
running again, it may be the gasket.
It could be that the unit is off balance making the door not even or
enough play in the door so that the locking mechanisim thinking that
the door was not closed try that.
Error Code: CL
Reason for the Code: Door switch open or door is open
Possible Component to replace: Door latch
Hope helps with this. Good luck.
