I have a Creative Gigaworks S700 i have checked both fuses still no power to control box
Stupid question: does the sound still work? it could be the LED just died after continual use (rare, since they last a long time, but not uncommon).
If not... it could be the controlling circuit board died. In which case, unless you have electronics repair experience, it would be probably more worthwhile to just replace the speakers, as pricey a model as it is.
all connections are good push in and never tampered with or moved since day one ....thanks for idea thow...but already checked.
forgot to mention the controller works on friends one.
nothing out of place inside...no damage or burning
sme thing has happened to me, switched it off on the remote, now its all dead and wont come on again!
I have the same problem, went to bed, the next day nothing the control pod dosen't work
Funny... same thing happened to me as well. if there is any solution on this I will keep you posted... Feel free to do the same for me :)
i have the same problem
same here... simply wouldn't turn on again, green light flashing on the back of the subwoofer.
i now have it open and i can heear this small click from the amplifier at the same rate as the light is blinking..
anyone! help!!!
i get the same thing happening.... and i took the back panel off of mine, and plugged it in and the ticking seems to be coming from one of the larger transistors inside. not really sure if it is fixable... and i was wondering if you need the audio control pad to use the system... i lost mine......
I got the same issue... Anyone got any ideas? Is this fixable?
