Question about Ovens
How do i fix error code F04 on Zanussi ZPB1260 single oven
  • 136 Answers
Error Code F04 is due to the mismatch between the incoming line voltage and the voltage setting of the oven. To correct the error code follow the instructions given below : a) Make sure the line voltage corresponds with the setting of the oven. The voltage selector is located at the back and consists of two plugs. The white plug sets the oven for 208 V and black plug (or white plug with a black dot) sets the oven for 230 V. b) Make sure the line voltage is within +/- 10% tolerance. This is especially important during summer months, where line voltage has tendency to drop. c) If both steps above check OK, the error(s) may be caused by defective controller (DPU) board.
Posted on Jan 20, 2010
Anonymous
SOURCE:
On my Fugor single electric convection oven: f03 error code. Error will not self correct after several times of turning off the power.
Web site quoted below:
Before calling for service, check the following to avoid unnecessary service charges.
Oven Problem
F03 or F04 Error appears in the display window.
A problem with latch mechanism occurred. Remove power and turn it back on again after a few seconds. The oven should run a latch auto-test. If condition persists, note the code number and call an authorized service.
http://www.google.com search result below:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwi0qdjJ18vaAhURuFMKHRjNBtYQFggvMAE&url=https%3A%2F%2Fwww.fagoramerica.com%2Fcontent%2Fdownload%2F4827%2F36165%2Ffile%2FFagor%25205HA_780X_Care%2520and%2520User%2520Manual%25200310.pdf&usg=AOvVaw1ewC8YnHKLRvnE5MVd2a1d
https://www.fagoramerica.com/content/download/4827/36165/file/Fagor%205HA_780X_Care%20and%20User%20Manual%200310.pdf
Apr 21, 2018 | Ovens
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 | Ovens
Oven door locked
put back in clean then cancle
May 25, 2010 | Zanussi ZBF360X Electric Single Oven
Zanucci Electrical fault. Oven cuts out and fO8
Is the model number correct. ZBF360X.
Anyway the error code fo8 normally relates to a faulty Tangential Fan.(Cooling Fan),which can be found on teh top of the cooker behind the control panel and it is there to cool said panel.
Hope this helps.
May 24, 2010 | Zanussi ZBF360X Electric Single Oven
What oven is the same size as zanussi zbf760
This is a standard single slot in oven.The sizes are below.
580mm Height / 560mm Width / 550mm Depth.Check with your local store.
Hope this helps.
May 17, 2010 | Zanussi ZBF360 Electric Single Oven
Zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
Dec 26, 2009 | Zanussi ZBF260 Electric Single Oven
Need English user guide for Zanussi zob 662 x
zanussi built in single oven outer glass door has just exploded any similar problems or reasons for this
Mar 29, 2009 | Zanussi ZBF360X Electric Single Oven
Setting Clock and Timer
Worked it out for myself - no solution needed now thank you.
Jun 21, 2008 | Zanussi ZBS963X Electric Single Oven
Zbs 1063 - POBERR 80
Take note of the error code(POBERR 80) and contact an authorised
Service Centre.
Nov 24, 2007 | Zanussi ZBS963X Electric Single Oven
Ovens Logo
297 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
