My external microphone jack and USB's doesn't work on Toshiba Satellite
My laptop is Toshiba Satellite P15-S420
It is two problems:
First: I tried to use canon scaner thru USB port, it worked great, but after usb stoped responding and I always get the message "Power surge on USB Hub"
Second: I was using my microphone, conected to laptop thrue external conection, and it stopped working. All playback is very good, but microphone doesn't work.
Thank you
I purchased a new headset and connected the microphone and headphone wires respectively into the front jacks. The headphones work fine, but he microphone does not seem to register.
i bought a toshiba laptop satellite series..when i connected my tv tuner card to it..the video recording is amazing..but the audio ( there's a lot of disturbance in the audio) when the audio is playing..i can see the video properly but there's a lot of screechy noise..i bought a toshiba laptop satellite series..when i connected my tv tuner card to it..the video recording is amazing..but the audio ( there's a lot of disturbance in the audio) when the audio is playing..i can see the video properly but there's a lot of screechy noise..
I got a Compaq Laptop & I bought a headset with a microphone..... The headphone works in s good condition...... buy the microphone doesn't even work........ Any good solution required.I got a Compaq Laptop & I bought a headset with a microphone..... The headphone works in s good condition...... buy the microphone doesn't even work........ Any good solution required.
Hi, I have tried the above option..... as you said, it was already selected ( Microphone )... So, nothing i can do now..... Can I get any further alternative solution.Hi, I have tried the above option..... as you said, it was already selected ( Microphone )... So, nothing i can do now..... Can I get any further alternative solution.
AnonymousMar 30, 2014
headphones and microphone are not workingheadphones and microphone are not working
You can't post conmments that contain an email address.
Re: My external microphone jack and USB's doesn't work on...
Hi, double click on the speaker icon on the bottom right corner, go to options, recording and select the microphone and adjust the level suitable.. thats it.. let me know
Follow the link below, it is an illustrated guide to the disassembly of the P15. Pages can be changed at the bottom of each page shown. Just copy and paste the link into your web browser's address bar.
Take apart laptop and see what type of jack is on your system. There are two types. one is soldered on and the other is a module that connects to the motherboard with a wire connector.
If you have a soldered on type the you will need to de-solder it from the board then solder a new one onto the board. most ac jack issue just need to resolder it unless the jack itself is broken.
cd tray button dead? means power failure. step one is remove that old bad shorted huge battery first. and run on AC pack only(even forever) bad power pack (or wrong kind) bad power jack on PC side it for sure needs service, guessing is not possible (or very expensive) if the P15-s420 (the dash matters ok./) Satellite P15-S420 (is the full name ok?) a true relic with only XP OS loaded. XP is trash, a pure virus magnet. 15 years old today. all batteries inside and outside are bad 15 years old not one will be good, and that is bad. the HDD will be bad too as will the CCFL LCD back lamps bad.(black screens forever) 2004 made, a pure relic with zero value.
worse yet is the DC jack is soldered down and all are cracked now. all are, if not parked on shelf for 15 years.
a better PC has pig tail jack that lasts 10x longer.
like HP 8540 has. and all top grade HP and Dell have.
not this toy grade old laptop
That will require a soldering iron, and a another battery with the same numbers. It is not a user replaceable part. the unit will have to be disassembled to access the battery properly.
On the Phoenix BIOS:
Go to "Advanced BIOS Features". Go to the "1st Boot device" and set it to "USB-ZIP".
(Phoenix BIOS, Revision 6. you need to go to the Boot Order screen and select "Harddisk" and hit enter, giving you a list of IDE hard drives this BIOS prefers to call a USB device an IDE harddrive)
You have to remove the DVD and after that you will see the HDD under metal shield held in place with 4 screws labeled M2.5X6. Screw to remove DVD was also labeled (F6).
If you don't know how to do it, i suggest to get on line the service manual for further info.
This will fix your problem.
Don't forget to rate my help! :-) Thank you for using FIXYA! Pablo
I have a Toshiba Satellite laptop and experience this problem with the mike stopping suddenly too. Your solution may not be as easy as mine was, but here goes ... Did you check the audio setup? Go to Audio Properties, and click Advanced so you can see the Microphone properties. Mine was muted and it wasn't me that muted it -- just seemed to happen suddenly and hopefully it's that easy for you!!!!
