Televison & Video Logo
Posted on Jan 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Westinghouse tv Mod.SK-32H240S COMES ON SHOWS THE
Westinghouse tv Mod.SK-32H240S COMES ON SHOWS THE BIG W AND GOES OFF
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
768
Points
Having the same problem and wondering if this solution worked :D
  • Benna Williams
    Benna Williams Jan 10, 2014
    We replaced the power supply/inverter board and now we have no sound and W only stays on the LCD screen a very short time/
Anonymous
Level 2:
An expert whose answer gotĀ voted for 100 times.
  • Expert 120 Answers
  • Posted on Jan 25, 2010
Anonymous
Expert
Level 2:
Answers
120
Questions
Helped
50380
Points
256
This model has what are called a LIPS board in it which is a board that has both the power supply and the inverter on the same board. What you need to do is replace this part and your TV will be as good as new. To obtain this board simply email [email protected] and they will let you know price and availability of this board. Please make sure to include model#, serial#, and TW#, all located on the back of the unit.
  • Anonymous May 18, 2010
    I am a Westinghouse technician, I am very confident this will solve the problem, if you have any questions please feel free to send me a quick email with your questions to [email protected]
Problem: Westinghouse SK-32H240S HDTV has a flashing/blinking blue/red power led
hi when the colours flash again, press the menu button on the remote control and retune the tv hope it helps
regards
shaun
1helpful
2answers
Need westinghouse tv model sk-32h240s service manual
Westinghouse TV SK-32H240S http://legacywd.com/pdf/111_User_Manual.pdf
1helpful
What's the vesa pattern for westinghouse sk32h240s tv???
The SK-32H240S has two sets of mounting holes 75mm x 75mm VESA or 100mm x 100mm VESA mounts.
I hope this helps. The manual is available here: http://www.retrevo.com/support/Westinghouse-SK-32H240S-TVs-manual/id/2727ag925/t/2/ . You will need to enter a code to download the pdf.
I have a westinghouse tv model number SK-32H240S the sound works but the picture dosen't if u turn the tv on the picture comes on for 1or2 seconds and goes out again
Hello Olga, this problem is normally caused by something on the power/inverter board (normally a transformer or a capacitor). If you are technical you can open up the TV and see what component is bad, you can normally tell because the component will leak or in the capacitors case be puffy. If you are not that technical you can also open the unit and simply pull all the plugs from the power/inverter board (big brown board on the left hand side when TV is facing down), take off all the screws, and replace the whole board. I can assist you with obtaining part #'s for this board if you would like just simply send me an email with the model #, serial # and TW # all located on the back of the TV as well as a brief explanation of what the TV is doing to [email protected]. Please rate my answer if it was helpful, have a great one.
I have a Westinghouse SK-32H240S 32" flat screen
First when tapping changes the picture you have somewhere a bad connection; in electrical board or wiring.
When the screen goes blank after a while means some capacitor is bad/old.
2helpful
2answers
I have a westinghouse tv model number SK-32H240S no picture
It seems that your unit has some sort of Video side, PSU fault, or a problem to the Video section that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
1helpful
When turning, on picture come up for 1/2 sec then goes plank,
My Westinghouse SK-32H240S television fails showing picture. Only sound can we hear but no picture.
2helpful
Has sound,picture only comes on for a couple seconds at start up.
This is a Backlight Bulb or Inverter (power supply for backlight) failure.
If in warranty, take it to service
You can try to order an Inverter, or if needed you can get a replacement bulb (not easily available)
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
