Question about Sanyo Xacti VPC-S770 Digital Camera
I dropped it & it said error 1114 then error 112.turn it on & it turns right off sanyo s770 lense stays out
    New Friend:
  • 76 Answers
Lens is out of place... refix and you will have right view
Posted on Jan 19, 2010
6ya staff
SOURCE:
Sanyo S770 lens won't retract on shut off and shuts down when try to zoom and get lens error
Lens error happens during the lens guide pin wrong movement. Please try these below and let me know.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 06, 2011 | Sanyo Xacti VPC-S770 Digital Camera
VPC S770 SANYO DIGITAL CAMARA
try a hard reset to tun it ON
Jul 31, 2008 | Cameras
I dropped my camer while the lense was out...and the lense stayed out.. can this be fixed?
Try reset all in camera menu or remove battery & reinsert or contact Fuji for exchange or repair.They sometimes go back on their own if you turn power on & off try gently twisting/pushing lens but be gentle with it.
Aug 12, 2010 | Fuji FinePix F30 Digital Camera
Lens Error 1114 the lens won't go back in and it turns off
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 28, 2009 | Sanyo Xacti VPC-S770 Digital Camera
Lens will not retract on Sanyo VPC-T850, 8.1 megapixel, digital
Did you drop your camera? If yes you either damaged the lense mechanical parts. If some dust or small particle are on the side of the lense, it may prevent the lense from opening up. If the lense opens up and down a little bite try to pull it out by have very softely. If it opened fully, clean up the outside of the lense and turn your camera a few times. If it does not have a mechanical problem, it should be back to normal. If above did not help, the lense has to be taken out and inspect for broken or damaged parts and clean it and put it back on the camera.
Good Luck!!!!
Jun 10, 2009 | Sanyo VPC-S880 Digital Camera
Broken Lense
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
May 30, 2009 | Sanyo VPC-E760 Digital Camera
My Sanyo VPC-S770 wont' turn on. i just bought it 1 month ago, what can i do?
I keep on getting Lens Error 1114 and my Camera doens't turn on. Why is that?
Sep 29, 2008 | Sanyo Cameras
Exilim ex-s770
First, check if you haven't set the camera for MACRO shoots, if so, only objects very near the lenses are focused. If is not the case you may have drop it and the lens got out of alignment.
Sep 05, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Sanyo s750 camera problem my cameras button to take a pic wont work
Mine dropped two feet on carpet, and it won't turn on. How do you access internal memory?
Mar 07, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Sanyo Xacti VPC-S770 Digital Camera Logo
218 people viewed this question
Top Sanyo Cameras Experts
Paul Green
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
