The dryer is not drying. The drying temperature is too low.
Hello there:
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being
supplied with the proper voltage. Here are three ways to make sure
power is getting to your dryer: First, make sure your dryer is plugged
in. Next, check the circuit breaker panel to make sure all the circuit
breakers are in the correct positions. Finally, check to make sure no
fuses in your fuse panel are blown. Any of these could explain why
power is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heating
element is defective. Heating elements are irrepairable. If yours has
ceased to function properly, you will have to replace it. Open your
dryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributed
to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is
no longer of any use. If your dryer's fuse is blown, you will have to
replace it. Open up your dryer's cabinet and locate its thermal fuse so
If any of your dryer's thermostats have become defective, they could be
the reason that your dryer is not heating. Open up your dryer's cabinet
and test each of your dryer's thermostats. If any are faulty, replace
them.
Timer motor
A defective timer motor could also cause your dryer to not heat up.
Test your dryer's timer motor. If it is no longer functioning as it
should, replace either the entire motor assembly, or just its motor.
SOURCE: dryer heats but only at low temperature. takes
Usually the relay (in the internal thermostat) is bad or if their is a second heating element, it can be bad. Also, the controller/timer can cause the problem but usually not.
Good Luck!
Testimonial: "thanks- the parts store man also said that a partially blocked vent could cause it"
SOURCE: the temperature is low, couldn't dry the clothes
It is most likely the heating element will need to be replaced. You can test it first to make sure it is getting power that is constant
SOURCE: My samsung DV219AG Dryer recently not working
CLEAN FILTER OR CHANGE TEMPERATURE SETTINGS. IT COULD BE FOULTY THERMOSTAT OR HITING ELEMENT
