My washing machine is showing OE error. I cleaned drain pump filter but still no result.
This is a drain error as you have figured out Good Job!
Now this can be caused from a broken impeller in the pump and or a plugged tub to pump hose.
Have you washer any rugs which may have came apart in the wash?
If so the hose from the tub to the pump may be restricted causing the code.
The hose will need to be cleaned.
This is a job best left to a pro.
Hello & Welcome to FixYa
OE is a drain error and is displayed when the
washer is unable to drain water. Please check the drain hose and drain pump
filter for any clogs to clean the error. Please get back to me if you have any
other questions.
Kevin
