Question about Panasonic Palmcorder SDR-H18 Camcorder
Problem installing ImageMixer 3 software on my Mac.
The ImageMixer 3 software that came with my camcorder won't work on my version of Mac OS X, which is version 10.4.  Can you suggest where I can get a version of ImageMixer 3 that will work on my Mac version or some other software that will work with a Panasonic SDR-H18 camcorder with a Mac OS X version 10.4?
  • 8 more comments
  • menta100 May 24, 2008
  • Anonymous Dec 04, 2008
    I have a Canon HD HF10 that came with the imagemixer 3 se software that is not compatible with my Mac OS software. I have been scouring the net to find a solution to this. Does anyone know what I can do, or where I can go to find a free version of the software that is mac and canon compatible?
    Cheers
  • daisyhamster Dec 25, 2008
    I have the same problem--I have a Canon FS100 camcorder and a macbook running OS 10.5.2.  The software supplied to me is the Image Browser for Mac, and the Image Mixer for PC.  I need Image Mixer for Mac.  Where can I get this?
  • ddbb Jan 25, 2009
    same problem.
    did you find where to download it?
    my projects are stuck on my camcorder.
  • Anonymous Jan 27, 2009
    same problem...have a Mac...any news?
    I have a Canon HG-20
  • fdunaway Feb 08, 2009
    I just purchased an HD COMS and have a new mac, but cannot install imagemixer 3 to upload any video. After researching all I see are downloads to purchase. HELP.
  • enstokes Feb 15, 2009
    I have OS X 10.4.11, and am looking for someway to get my video onto my iMac.
  • Anonymous Feb 21, 2009
    same **** ... **** canon
  • Anonymous Mar 11, 2009
    Canon is pissing me off.
  • Anonymous May 25, 2009
    Our software provided doesnt work eirger
I just got off the phone with Canon support. I have a Canon HF 100 and was experiencing the same problems. If you have the newest version of iMovie (in iMovie '08....but I would bet '09 would work fine as well...'06 is questionable), you shouldn't have any trouble getting the files off your camera onto your Mac.
Steps:
1. Plug in the camera and turn the power on (or plug in the memory card via a card reader)
2. Open iMovie
3. Wait a few seconds to see if your camera connection automatically opens, if it doesn't, click on the image of the camera on the far left side of the middle bar in iMovie.
4. It should recognize the video information you have plugged in at this point. If it doesn't, in the bottom of the import window, see if you can select a camera from the drop down list next to where it says "camera" in the bottom left.
I was told by the tech support people that I need to update my Final Cut Express software in order to read the video files, however I think they're wrong because I'm pretty sure I have the newest version. I also just found this information on Apple's website useful (see the video entitled "Built in AVCHD"): http://www.apple.com/finalcutexpress/ If you're using Final Cut Express 4, go to File -> Log & Transfer (or hit SHIFT + COMMAND + 8 on your keyboard) and if your camera/memory stick is plugged in, it should show a list of your files right there. Much better than iMovie.
Here is some information on the stuff I am using if it's useful:
iMovie '08 version 7.1.4
Final Cut Express 4 version 4.0.1
Canon HF 100 Digital HD Camcorder
Mac OS X Leopard Version 10.5.6
Hope this is helpful. I doubt that I will check back to this forum, so please email any questions you might have (I may or may not be able to answer) to bbaumgar@ucsd.edu. I would recommend, assuming you have a Mac, going out and buying iMovie '09 ($39 - $79 depending where you buy it), Final Cut Express ($100 - $300 depending where you buy it), or Final Cut Studio 2 ($400 - $1200 depending where you buy it) before spending money on another software that won't let you do as much. The Imagemixer 3 software that your camera came with is supposed to let you basically do the same things, but doesn't work on Mac. It looks like you can buy the Mac version from Pixela...but I would encourage you to contact Canon or Pixela support first and demand a free one, since you paid so much for the camcorder and should be entitled to the software.
Canon tech support was pretty useful as well: 1-800-828-4040. I only had to wait about 5 minutes. (The total call was around 15 mins).
Good luck.
-Brian
Posted on Feb 13, 2009
  • milenekag Jul 27, 2011
    Hi, your post was very usefull for me, but I have a question, do I need to buy the Finalcut or only the Imovie is ok? I have a Canon Vixia HFS10 and want to burn dvds trought my MacBook.
    Thank you.
  • cbleone
    cbleone May 05, 2012
    Thank you Brian. It worked! I followed you sequence to the T and waited and at one point I thought no, and then a window pop up saying it was generating something or other and a few minutes later it asked if I want to import the raw video.
    New Friend:
I was recently given a Canon HF200 which came with the usual Windows image maker discs but no mac discs: I plugged it in, opened iMovie09 and hey presto, iMovie found it and gave me the option of downloading the video clips. It does work and I hope thats the cheapest way for people to sort out this Canon defect. Saxy
Posted on Apr 29, 2010
    New Friend:
  • 74 Answers
Canon didn't bundle any software for use on Apple's, so all of us Mac users are stuck with iMovie/iDVD or Final Cut Pro. As for the PC users, they get to install the bundled software because it was provided to them from Canon. I will assume that Canon is assuming that their bundled software is no better than what Apple offers so why bother providing it for Mac users. That's why you have to pay for it, if you want to use it. Why do you want to use Imagemixer 3 anyways?
Posted on Dec 15, 2011
Hi  I can see this is a bit belated but you can purchase Imagemixer 3 for mac.  I've just purchased it and am now battling with it to get it syncing with my Canon HF11
Posted on Jan 26, 2009
I have a panasonic hdd camcorder , 42x optical zoom. I just bought a mac computer. What software do i have to install in order to transfer my photos and movies to my mac computer?
Posted on Oct 14, 2008
    New Friend:
The directions (above - solution #1) for using imovie to import the video from Canon above work perfectly. In fact, I downloaded the videos to both a PC (lenovo/thinkpad) and a macbook 09 and I am amazed at how awesome imovie seems to be compared to ImageMixer. The former just seems so much more intuitive and easy to deal with.
Posted on Feb 03, 2010
Well at least you got the software with your for your mac..  I didn't. The company won't send it to me either they say I have to buy it for 100 bucks..   jsodlo@hotmail.com
Posted on Aug 15, 2008
6ya staff
SOURCE:
How can I download the software for ImageMixer 3SE? I have misplaced the disc for this software and need it for my Cannon camera Vixia HFR100
You can download some software for the Vixia HF R100 here: https://www.usa.canon.com/internet/portal/us/home/support/details/camcorders/support-high-definition-camcorders/vixia-hf-r100 . However, ImageMixer 3 SE is third-party software that is only available on the driver disc that came with the camera. Some companies will send you a replacement disc for a small fee. You'll need to contact Canon support, https://www.usa.canon.com/internet/portal/us/home/support/ , to ask if they have discs available.
ImageMixer 3 SE is available here: http://www.pixela.co.jp/oem/canon/e/imagemixer3_se_canon/ . However, this is only for updating the software on a computer that already has the program installed.
I hope this helps.
Apr 09, 2016 | Cannon Video Cameras
Lost my imagemixer 3 for panasonic sdr-h200 camcorder in a fire. Where can I download or get a cd.
I have lost my panasonic SDR-H18 imagemixer 3 CD software disk. Is it possible to buy a new disk, or download a copy
Jan 14, 2012 | Panasonic SDR-H200 Camcorder
I can't find an imagemixer se3 manual.
When you are typing in the serial number, ignore the last two letters. Type only the digits.
Apr 26, 2010 | Canon Computers & Internet
Last year in November ? December my son bought a camcorder CANON HF 11, supplied with ImageMixer 3 SE Ver.3,(on CD ) Ver.3.1., which was installed on a laptop ACER Aspire (Windows XP) and worked properly...
Hit your windows button on bottom left of your desktop screen go to search and type in search box .vid or .mp4 or if you know file names type it in search box, let me know what you find
Nov 23, 2009 | Canon Video Cameras
Is it possible to download ImageMixer for my Panasonic SDR-H20
The imagemixer version that came in the CD-ROM with the camera may no longer work with Windows Vista. A new version, inagemixer 3, has been developed for Vista. You download it from this website. The installation procedure is also provided on this website.
Oct 21, 2009 | Panasonic VDR-D100 DVD Camcorder
ImageMixer 3 SE for SD. Can't Create Disc, Save Files to PC
This has to be the shittest software ever! I've edited my clips in the editing mode but can't do anything but save it as a working edit. The file format is useless for anything but this program so all you can do is edit to your hearts content and then edit some more. Complete waste of time. I tried connecting the camera (Canon HF10) and that took away all editing options. Could only burn straight to DVD or upload to computer. For such an expensive camera this is very disappointing.
Mar 12, 2009 | Hitachi DZ-HS300A DVD Camcorder
Canon HS10 camcorder and Imagemixer 3
To play the audio you need to download the AC3 filter pack here: http://www.free-codecs.com/AC3_Filter_download.htm. I have no idea why Canon didn't bundle this codac with all of the software they provide, but it worked for me. I use a Canon FS100, and had no sound in WMP (or any other Windows apps except VLC Media Player) until installing this.
Nov 09, 2008 | Computers & Internet
Panasonic Palmcorder  SDR-H18 Camcorder Logo
18,145 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
