For resetting up your d-link router password you have to follow these steps..
1. open your browser and type 192.168.1.0 and type user name and password
2.go to wireless settings . you can also restore d-link router settings .
3. or you may can press the reset botton on the back of your router .for more technical help contact d-link Tech Support .i hope this will help you..thanks
T%here is a small recessed hole on the back panel of your router. You can use something like a straightened out paper clip to push into this hole, holding it down for approximately 5-10 seconds. Your router will then be reset to 'Factory Settings.
to reset the D-Link to the Factory Default Settings, please follow these steps:
1. Turn off the router
2. Locate the Reset button on the back of the router.
3. Use a paper clip to press the Reset button and power on.
4. Hold for about 5 seconds (don't hold too long) and then release. (Or, release when M1 and M2 flash at the same time.)
5. After you have completed the above steps, the router will be reset to the factory default settings
