Is there a fix for being able to scan from the hpj3680 printer/scanner. on windows 7. It printed but wont scan after i upgraded from vista to windos 7
Hi Melinda,
Windows7 provides a basic set of scanning drivers, also referred to as
Windows Image Aquisition (WIA) drivers, that you can use as an
alternative to scan a document when you cannot scan using the HP
drivers. You might choose to use these scanning drivers for one of the
following reasons:
ScanningUse one of the following three methods to scan a document.
Method one: Scanning with Windows Live Photo GalleryTo scan a document using Windows Live Photo Gallery in Windows7, follow these steps:
Method two: Scanning with PaintTo scan a document using Paint in Windows7, follow these steps:
Method three: Scanning with Windows Fax and ScanTo scan a document using WinIs there a fix for being able to scan hpj3680 - c01319360.gifScan in Windows7, follow these steps:
Please reply if the problem persists.
Regards,
Rizwan
Kindly download the driver for windows 7 from this link then you will be able to scan,
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3440995&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=3440986
Please download and install the scan driver from support.lexmark.com. After installing the scan driver, please check the scanner under Imaging Device from device manager. If scanner shows under imaging devices, open the scanning program and scan a document.
For further assistance, please contact Lexmark Technical Support.
To check to see if your scanner is properly installed, open the Device Stage. Choose Start?Devices and Printers. If Windows doesn't automatically find your scanner, you can manually add it in the Devices and Printers window by clicking the Add a Device button in the toolbar and following the wizard's commands.
Choose Start?All Programs?Windows Fax and Scan.
Windows 7 opens the Windows Fax and Scan window.
Click the Scan button in the Navigation pane, then click the New Scan button on the toolbar.
The New Scan dialog box for your scanner opens.
Use the settings on the right to describe your scan.
By letting the computer know what you're scanning, its color profile, and the type of file you plan to create, you enable Windows Fax and Scan to create the highest quality scan.
Click the Preview button to see what your document will look like.
Make any last minute changes.
If you're happy with the preview, click the Scan button.
Windows scans the document and presents you with an image of your document.
Click the Save As button and complete the necessary information.
Enter the filename, the type of graphics file you want saved, and then click the Save button.
To automatically forward the document you've just scanned as an attachment to a new fax message, click the Forward as Fax button.
The scan feature in the Windows Fax and Scan utility is set primarily to scan text documents. If you want to scan a photograph or other graphic, you're better off doing that directly within the Windows Live Photo Gallery.
Read more: http://www.dummies.com/how-to/content/how-to-scan-a-document-in-windows-7.html#ixzz15JFYWJQ1
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
