Acomdata 250 external hard drive with a SATA connection suddenly not showing up on desktop running G5,OSX. Drive is spinning, solid blue light on. Connectios are good. When I pull the data connection, desktop recognizes a device removal, but that's it. I understand that Acomdata uses OS system drivers in this case.
Thanks
john
SOURCE: running mac osx my acomdata external drive lights
This is the solution that worked for me.
Luckily I have another external drive of the exact same model that is working fine.
I used the power supply from the good working model and plugged it into the bad drive. The bad drive booted right up. Evidently the power supply was the issue, not the drive itself.
Even though the bad power supply had enough juice to light up the drive, it was not able to make the drive spin correctly.
SOURCE: using acomdata hybriddrive on multiple os
If you're not going to use the included software then you should partition the drive for both of your os' (it is a fat32 drive).
SOURCE: I have been using an Acomdata (HD250UE5-72) 250 GB
It is compatible with a Mac and will not require a re-format.
