Sure..the speakers are toast, or the connection is fractured. You may be able to inspect the connection by removing the keyboard, but it's usually buried under the palm rest.
well..that's unfortunate. Using the Inappropriate selection makes it difficult to take this to the next level, don't you agree? Good luck with your issues.well..that's unfortunate. Using the Inappropriate selection makes it difficult to take this to the next level, don't you agree? Good luck with your issues.
You can't post conmments that contain an email address.
Yes, for most movies the surround speakers are for music and background. Unless the person speaking is supposed to be behind you, the voice will not come from there.
Sorry, I made a horrible mistake.Your av-amp only gives you 2 tick......Tat sounds instead of 3 tick......Tat......tick sounds ,(3rd sound coming from speaker relays never coming out.). Download onkyo htrv330 service manual. Find out those components and fix them to make sound again
Hello A sudden stop of sound output while the set works denotes either its speaker or audio output IC damaged. Check the speaker first by using a multimeter for its voic coil continuity. If speaker is OK, the fault is surely with the audio output IC. It should be replaced with same type and number. It is a semi-skilled work, you have to open your tV, locate the audio output section. You must have knoledge in electronics to do this work. OK.
Audio but No Video/Picture Problem can be fixed with the help of This DIY Video Guide, I would suggest you to give it a try as it also provide Money Back Guarantee.
Note:
If you are facing this problem either you can send your Xbox to
Microsoft for repair, if yon can wait for 2-3 weeks then it is good
otherwise you can fix the problem yourself within an hour with the help
of above Video Guide.
hi.. sir please follow the step's 1. start 2. control panel 3. sound and audio devices 4. voice 5 test hardware 6. follow the step next .. itwork's is ur audio device is correct. thank u sir don't forget to rate it..
This is going to be a problem either with the sound card malfunctioning after the machine warms up, or feed back from the speakers due to a wiring issue. Either way, this is a hardware problem, and you shouldn't have this or any problem with the machine, especially with it only being 10 days old. Take it back for an exchange. Demand an exchange and don't let them give you the run around. When you get the new machine, you will see that you shouldn't have any problems with it for years to come. Also, don't let this bother you about Dell machines, they're one of the best machines on the market. Just like everything else, there are a few lemons.
Have the speaker checked out and if it checks good you need to take the amp back to the repair center and have them test it better. Most repair centers have a 30 day warranty on the work they perform. Make sure they know what the problem is in detail, so they know how to check it properly. But my first thought is the speaker could be faulty. You can check the speaker yourself by switching them at the amplifier. If the same speaker sounds bad you know it is the speaker that is bad. If the sound is bad from the other speaker, then the amp is bad unless it is coming from the head unit. You can also switch the RCA input jacks after that and see if the problem changes speakers, if so, the RCA output of the head unit is bad, but that is less likely.
Put your mouth over the speaker & blow gently, if the diapgragm in the speaker is faulty (probably) this may lodge it back into position. Try it, nothing to loose.
I don't knnow how to procede
