Greetings,
Here's an easy to understand and follow video review on how to attach the carpet shampooer to the Kirby Generation 6 (G6). The model that's being used in this video is a little newer model, the Sentria, but the procedure to attach the carpet cleaning attachment is the same exact repair on the Sentria as it is on your Kirby G6 vacuum.
I hope this helps!
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
If that helped, please be kind and rate the video as helpful by clicking on the Thumbs Up Icon below. If you have any questions about how to install it, please just request a repair clarification and I'll be more then happy to help you.
Thanks for watching!
Chris J.
SOURCE: kirby diamond edition - shampooer
1. Raise the vacuum head all of the way up. 2. Remove the vacuum head by removing the belt and releasing it. 3. Place the shampooer head on the vacuum by securing the clamp and them put the belt on 4. Take the bag off of the vacuum by twisting at the base just slightly outward and lifting upwards and unclamp it from the handle 5. Put water and cleaner into the water resevoir. 6. Put the reservoir on to the kirby where the bag was by holding it parallel to the vacuum then using both hands, twist it outward slowly until it goes down onto the unit then twist back to parallel position. 7. Put the coil looking piece on the shampooer head on top where the hole is...it will only fit one way successfully. 8. Put the other end on the under side of the water reservoir. 9. Lower the shampooer head all of the way down on the carpet just like you would the vacuum head 10. Turn on the vacuum and reach down and turn the knob at the top of the reservoir, this will begin putting cleaner (tons of foam) onto the carpet. Just work in 3' x 3' sections, turning off the foam intermitently until you are finished. I hope this helps.
SOURCE: Kirby sweeper shampooer attachment HOW TO use it
Please follw this link to view my carpet shampooing guide. Hope it is helpful!! :0) Marci
SOURCE: shampooer instructions
Here's my online guide for using the Kirby shampooer.... HOPE IT HELPS!! Marci
SOURCE: Kirby Vacuum Shampoo Attachment
Try following these directions....
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
SOURCE: Kirby G6 Shampooer
Here is a link to my online guide for carpet shampooing....
Hope it helps!
If that is not enough info, I have manuals available.
Marci
