Timex Expedition 84601 Wristwatch Logo
Anonymous Posted on Jan 18, 2010
Alarm on timex indiglo won't turn off
I was trying to set time on timex indiglo, alarm started solid BEEEEEEEEP will not stop no matter what I push. It's been sounding the same constant BEEEEEEEEEEEEEEEEEEEEEEEEEE for 15 minutes, how can I turn it off (or should I hit it with a hammer?)
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3683
Points
5
It's just a cheap watch, one hit with a hammer and the alarm stopped.
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Feb 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
13040
Points
22
It's very simple hold all three key together except INDIGLO one.
BTW
It's a nice watch!
8helpful
How to turn off alarm
4 buttons ( mode, start/stop, indiglo, and adjust)
1. Look under the time and see what type of symbols are by the seconds to see if the chime or the alarm is set or both
-The chime looks like a pacman symbol and the alarm looks like a bell
2. If both symbols are present hold down adjust and hit start/stop twice
If only the alarm or bell symbol is present hold down adjust and hit start/stop once
Hope this helps and it should turn off the alarm :)
Ladies black indiglo 1440 sports watch approx 8 years old.buttons st/stop,lap/reset,mode, indiglo (clockwise). Lost instructions. can you help? I cannot (do not know how to ) set the time, date, day or...
You can get instructions from the Timex web site "timex.com".
At thebottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Feb 13, 2010 • Watches
187helpful
Timex 1440 sports wach chime disable
Press the mode button until the Alarm apears. Press the Start/Stop button to turn the alarm on/off and remove/add the chime. Whew! I had to figure this out after my 3 year old turned the chime on!
36helpful
2answers
Alarm
On this 1440 watch to cancel the alarm first push the adjust button (bottom right on this watch) this will bring up the alarm time previously set and while still holding the adjust button tap the stop/start button (top right on mine) this should deactivate the alarm
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
90helpful
3answers
Timex Indiglo WR 30M
to turn off hourly chime on the times wr 30m, simply press (in any mode, i just use the regular clock mode) the start/stop button (top right hand button) once (for about half a second).
  if you don't hear anything, you've turned off the hourly chime!  if you hear two short beeps, you've turned on the hourly chime.    turning the chime off/on is cyclic.  if you press once and hear nothing, it's off.  if you press again, you'll hear two beeps and the hourly chime is now on.    a lot of times that button hits my wrist (i wear it on my left hand) by accident, and that's how the chime turns on and off.  i hope this helps someone.
5helpful
2answers
My timex indiglo watch beeps on the hour. How do I take it off so it does not beep on the hour?
Thwat is the chime. Some how it must have been turned on. Somewhere on the watch you will see a little bell or wave figure )))) There is 1 of 2 ways that you chime can be turned off. The first way to try is to push both buttons on the right hand side at the same time that should turn off the chime or the alarm, but if you do it more than once it will turn off whatever wasn't turned off the first time you pushed the button, and if you push them again, it will go back to the configuration you started with. The second way would be to go to your alarm modeand push the button that is NOT your light button or your "mode" or "adjust" button and push that button, that should cycle through the charm and alarm as went through before. If you find that neither one of these ways work, send me the model # and I will get you the information you need. PLEASE if you still have problems let me know!! Good Luck!!!
3helpful
Setting alarm on watch
You should be able to download the manual for your watch at the site below. If you cannot, contact Timex for support.
http://assets.timex.com/manuals/index.html
Jerry G.
3helpful
2answers
How to set
in order to unset the military time on the watch you must hold down the two top buttons until the the 12 hour format comes back. in order to turn off the alarm you must hold down the two right buttons until they beep..and then the alarm will go off
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
