Maytag Neptune FAV6800AW Top Load Washer Logo
Posted on Jan 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a fav6800 maytag washer, I am getting a UC code. If the drain is blocked in someway will it give this message? the machine works fine till it comes to the rinse and spin and then error code comes up.
Anonymous
Level 3:
  • Master 526 Answers
  • Posted on Jan 18, 2010
Anonymous
Master
Level 3:
Answers
526
Questions
0
Helped
143125
Points
1214
What are the first to digits of your machines serial number? It will be 10 thru 17.
Did the machine bang around in Spin Cycle during the wash Cycle with the uC error code?
The FAV6800A and it’s sister FAV9800A LCD display version of the machine suffer from a chronic Dry/Rusted One-Way Roller clutch issue. See this Clutch repair post on this forum for clutch maintenance and or replacement and this post on another forum. Read how to check the failure of the One-Way Roller clutches to slip in the CCW/Spin direction at this post.
If you are just a bit handy you can do the maintenance or order a replacement from AZ they have the best price around $56. I will help you every step of the way…..Rich
Couple of links to the Service Manual and Sears Parts Direct for reference.
I’ll paste in how to check the Tub Displacement Sensor. I don’t feel that is the issue but is will give you a chance to go into Service Mode and check thru the lid for proper operation.
Tub Displacement Sensor Diagnostics check. This test is done with the washer lid raised see page 19 of the SM for the details.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you get these results your TDS sensor should be just fine and not the cause of dC or uC unbalance errors……fix the clutch and your machine will be
J
  • Anonymous Jan 18, 2010
    Forgot to mention your drain is not blocked you did not throw ND error to the display correct?
    What a lot of folks and repair people don't understand is the machine is designed to enter the Spin Cycle of the Wash Cycle with almost a full tub of water.
    I feel the Maytag design folks did this to help dampen out tub oscillations at the start of the Spin Cycle.
    Bet if you do a Spin Only cycle with no clothes in the wash basked the Spin Cycle will complete. In the other forum post I give some insight into what is happening when the One-Way Roller clutches fail to lock up rock solid in Spin direction/CCW direction of the wash basket. Post back if I can help…..Rich
Rottiecrew
Level 1:
Problem Solver:
  • Contributor 3 Answers
  • Posted on Aug 11, 2012
Rottiecrew
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
846
Points
Don't know the cause but I have same problem and found that if i turn the machine off when the code pops up (should be with about 12 minutes left in cycle) and then push spin and start it will finish rinsing the clothes and spinning them out - been doing this for months just fine
How to access drain pump on maytag neptune FAV6800 top loader washer
The drain pump can be accessed by removing the rear panel and following the hose down
2helpful
2answers
My Maytag FAV6800 will not spin the clothes
Here is a Fix if your machine model is a FAV6800A or FAV9800A failing in Spin Cycle with dC/uC unbalance errors.
Fix the Clutch issue and save your 1$K machine. Here is my Clutch Fix post. You can redistribute the wash load in your FAV6800A or FAV9800A till the cows come one and you will continue error out in Spin Cycle of the wash cycle or a Spin Only Cycle. I explain in this post the fix and how to diagnose the issue to the Clutch Pulley One-Way Roller Clutch bearing.
If you just need Clutch maintenance you could be back in service today. You or someone you know can do this and I will help with any questions…………Rich
1helpful
3answers
Getting dc error code in rinse cycle, 13 min. before being done Have un-pluged and still getting code. Maytag FAV6800 LED washer, 5 years old.
Hello rdberg,
See this post Clutch Fix it has helped a few owners with the dC and uC unbalance errors with the FAV6800A and FAV9800A machines. You have a very common problem with a Clutch malfunction. The first part of the post has to do with the nuts and bolts of disassembly and Clutch maintenance or replacement of the Clutch Pulley.
In the last part of the post I go into just how to check the One-Way Rollers clutches to verify that are locking up. If they don’t this results in tumbler movement on Wash Basket spin up and the unbalance errors. If you are handy and have some basic hand tools you can get your machine back in service at low cost.
Post back if you have questions…..Rich
2helpful
2answers
Receive code "dc"...water will not drain and tub will not spin properly
This is my failure resolution with DC/UC error codes a common problem with this model;
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors in the spin cycle, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium and heavy loads and all work fine no unbalance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a cycle with no dc/uc error codes.
I found a Service repair manual on this site search for this; FAV6800 Manual
Maytag neptune mah8700. Will spin at the end of quick rinse cycle but not on any other cycle. Error code I get is SUSP. Washer does drain out.
Hi
My name is Gloria, my neptune washer will not spin on the last spin cycle of any of the washing cycle. A code of uC comes up.
1helpful
Neptune won't advance from Rinse to SPIN
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(@#$^
I have a washer fav6800 it wont spin code is uc
Un balanced load, This is a machine that should have been re called.Sorry , but its very true.
1helpful
Maytag washer wont drain
You most likely have a bad drain pump.
2helpful
2answers
Unbalanced Load (UC) Message
4helpful
2answers
Maytag Neptune TL
What error codes are you getting?
This is my failure issue with DC/UC error codes a common problem with this model;
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
