SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
SOURCE: How do I take off Whirlpool Washer cabinet to get to the pump
Ultimate Care II LSQ9564J
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LSQ9564J
click on your model number. The new window will give diagrams in the left-hand side.
Click on the diagrams. This will show the assembly of the unit. Use this as a guide for dis-assembly and re-assembly and do not mix-up parts as they are removed.
SOURCE: How to separate auger from agitator. whirlpool ultimate care II
When you look down into the agitator, are there 4 white plastic points that look slightly melted or otherwise deformed? If so, using a small flat head screw and a small hammer, separate the white plastic from the surrounding translucent plastic. Once you've done that, it should easily pull apart.
