I have a narrow crown air stapler that will not fire, just hisses. Not jammed. Rebuild? If so what parts and where is best place to get them? Tx, John
Before going about rebuild get can of carburetor spray cleaner and stray the ram area lots of times the glue that holds the staples/or nails builds up and stops up the ram rod spray the rod a few times than with air hooked up dry fire if it frees up lube rod area
yes thats the rod if it has no tension and loose the internal spring or the retainer on rod possible broke u can contact bostich at bostich.com or 1-800-556-6696 they have parts & support online or can divert u to a local repair shop--also check in your area for a tool rental and ask where they get tools repaired
hohox5,re the Bostich narrow crown stapler, is the ram rod the "front" rod that has to be contracted before you can shoot the gun? If so, the rod is sloppy loose and has no tension.
