Microwave Ovens Logo
Posted on Feb 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My microwave turns on but does not heat up it is only 6 months old wot can it be
  • cathy3739 Feb 15, 2009
    Mine is a GE Sensor Microwave, Model #WES1450DM1BB. I bought it for an elderly woman and her handicap daughter. They can' find any of the paperwork that I left them. I bought it about 6 months ago. I was manufactured in Jan 2008 which should prove it is still under warranty. Does anyone have a # that I can call about this?
  • William Miller
    William Miller May 11, 2010
    Since it's only 6 months old, I would contact the manufacturer's customer service department for them to repair it at no charge.
    If you don't have your owner's manual, please reply back with your brand and model, I should be able to give you contact information.
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
  • Posted on Feb 11, 2008
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
783122
Points
6681
It may have a defective magnetron. If this microwave is 6 months only, still under manufacturers warranty and you should take it for repair.
The magnetron has a warranty of 5 years in some cases, read the warranty section of the users manual.
Good Luck.
My microwave turns on, turntable turns, just won't heat. the microwave is 6 years old. Is it wiser to bring in a repairman or just replace? there is a picture of the microwave by the timer window.
There are 2 fuses inside the cabinet. One is for the clock and turntable. The other is for the high voltage transformer and the microwave module. If this fuse is blown either the transformer is shorted or the module has failed to cause the fuse to blow. Parts and Labor can get close to the cost of a new one, so get an estimate so you can have information to make your decision
1helpful
Microwave is 6 monthes old. will run table will turn but not heating properly hearing strange sound and smell.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Have a cookworks microwave model AM821AHT-X2, only 6 months old and just suddenly stopped working properly,not heating up,timer and lights are working but no heat at all.
Basic Microwave Oven Troubleshooting Tips
heatman101
8helpful
2answers
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. It is only 6 months...
Small component called a diode. Open up the microwave and try to find a black (usually) component that is most often connected between the magnetron (the thing that heats the food) and the chassis of the microwave oven (ground). I used to make a fortune replacing these! Costs about 5 bucks most appliance supply stores. Make darn sure you get one of the same value.
Microwave taking much longer to heat food
The microwaves are produced by what is known as a KLYSTRON TUBE. Like anything, early failure is possible. There is also the possibility that the transformer or electronic circuit providing the correct voltage to the KLYSTRON has failed, either from over-use, manufacturing defect, or leakage from the KLYSTRON enclosure, which creates heat.
With microwaves being as CHEAP as they are, replacement should not be an issue.
My sharp microwave is under 6 months old. I was
It may be a shorted high voltage diode.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
1helpful
2answers
Cookworks microwave not heating up
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
If for some reason you don't have your owner's manual, I would suggest calling the dealer where you bought it to see if they have a number for Cookworks.
3answers
Mvh1615
It doesnt matter how old a system was. components can be failed at any point in time. unplug the unit. carefully disassembly and visually check the diode near magnetron and capacitor, it might be broken.If seems good, check the thermostat continuity,if beeping. changage your magnetron. be careful capacitor store charges that deadly. discharge the capacitor first.
when you change mag. change the diode too.
2helpful
3answers
Microwave won't heat food.
built in 3/94 is it worth fixing how much for magetron
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
