LG 42LC2D 42 in. LCD HDTV Logo
Posted on Jan 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Invalid format error with P1600 blu-ray and LG LCD TV 42"
I get an invalid format error when I attach my samsung P1600 blu ray player to an LG LCD 42" TV and I'm also using a monster cable HDMI 960. Please help. Do I have to do firmware upgrades on my TV is that possible? Or do I have to upgrade the firmware on the blu-ray player? Or do I replace the blu-ray player? Thanks.
  • Anonymous Mar 20, 2014
    resolution settings set to auto, reset player but still reading invalid format
  • Anonymous Mar 22, 2014
    I need help
Mike
Level 2:
  • Expert 166 Answers
  • Posted on Jan 18, 2010
Mike
Expert
Level 2:
Answers
166
Questions
0
Helped
90309
Points
408
It may be a firmware issue if hdmi works with other items such as playstation.
If no hdmi the main Pcb hdmi ports are bad and the main Pcb would have to be replaced.
Consumers cannot upgrade the firmware so a shop would be the only option.
I have a sony blue ray DVD player and when I connect it via HDMI cables into either HDMI1/DVI or HDMI2, i get the message invalid format. I've tried multiple cables, multiple LG TV's, and the it...
Tries tv unplug,replug it back like about an hour later.Than tries go into the tv menu do a resetting to factory setting in every settings on the tv.Than reconnect the Blu Ray player again should work.If not the tv and Blu Ray player softwares main firmware just not compatibles.The only solution is just don't used it on this tv,because if u tries to upgrade the tv firmware or the Blu Ray firmware and u get the wrong upgradable version in the tv or Blu Ray player.That it u in deep ****,than the tv or Blu Ray player well not functions at all or have multiple orperational problems during it playing times.
When we plug the blu ray player into hdmi port and audio ports, we are only getting sound. The tv gives us a "no signal" and "invalid format" yellow box error.
Hello
Unfortunately your TV is only HD ready. This means that it plays video in 720p. A full bluray disc is 1080p. Im afraid your tv will most likely not be able to handle a bluray player.
:( sorry
Hope this helps
1helpful
2answers
Receive an invalid format message from my Olevia 32 tv
You get invalid format, or format not support becuase the video resolution setting on your PC is too high for the monitor to display, you need to lower your PC video resolution to the native resolution of the TV to get the best picture. Look at the owner manual for your TV or search the web.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Cannot see video after connecting lg42lc2d with
If you are using the cable for HDM1, maybe the cable it's not good, try another cable or another input on the TV
2helpful
2answers
I have an LG 42LC2D TV with INVALID FORMAT ON HDMI2
I have had this same issue.
Problem your tv isnt true 1080p meaning it will not work however when you switch to componet cables goto menu then change the display settings to 720p or 1080i then your HDMI connection should work fine.
Our new Samsung Blue Ray is showing "Invalid format" what do we do?
check with Samsung there just might be a firm ware update for you "new " Blue Ray... their site will show you how.
Invalid format
Try rechecking all wire connections for proper placement and fit too and from the tv.
Try adjusting the video format on the DVD, flip through 480p and 1080i. See which format works best with your tv. Do the same with Wii.
See if this helps.
7helpful
2answers
Invalid format
my xbox 360 when hooked up to my 42inch Lc7d get sound but displays invalid format error,  how can this be fixed?
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
