MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard (7592-030R) Logo
Posted on Oct 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have had a motherboard failure the MS-7357 (V1.X) Mainboard... needing upgrade thinking of the MSI G41TM-E43 LGA 775 Intel G41 will i have to mess arround with the power switches with the case as this was a premade build the reset and power switches are in 1 solid block. just wondering if these 2 boards have the same setup for power switches
goneforever.
Level 3:
Top Expert:
  • MSI Master 14,531 Answers
  • Posted on May 23, 2022
goneforever.
MSI Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263647
Points
66315
The ms, 7xyz series is a relic
all that matters is the size of mobo, to case
ATX or microATX
some or most cases (not oem) do both sizes
and none told by you case , maker and model
but just looking there under mobo shows what screw stub holes are there for both. or not.
the power switch is just 2 pins and easy to rewire.
the manual on both cover all that but no case told.
4 Related Answers
A
Anonymous
  • Posted on Mar 20, 2008
SOURCE: power light and fans come on but no post or boot up
hi there, i've got the same problem and tried all that was suggested. still no luck. what can i do?
Anonymous
  • 2961 Answers
  • Posted on Sep 09, 2008
SOURCE: upgrade for mbd ms-7357
Click here for live update page for auto recognition of your motherboard to inform of bios and driver updates
proton77
Mandeep Singh
  • 1184 Answers
  • Posted on Aug 15, 2009
SOURCE: reset bios on MSI ms-7301 motherboard
Kindly visit the following site
http://www.msi.com/index.php?func=downloadindex
Select the correct model number for your mainboard or motherboard and download the user manual for the same. It has details on how to reset the cmos or the board using the jumper settings
Thanks for using fixya
proton
Anonymous
  • 93 Answers
  • Posted on Mar 07, 2010
SOURCE: g41tm-e43 + windows 7:
just install ur orignal window 7 driver for ur motherboard
http://www.msi.com/index.php?func=proddesc&prod_no=1791
follow this link
Audio bus driver
Go to the intel site. They have these audio drivers for all intel motherboards.
1helpful
Gigabyte GA-G41M-ES2H LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard
Hello here is the homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=3468#ov
A new hdmi connector, can be ordered by a gigabyte dealer.
But changing the connector, is not a do it your self job.
I suggest you to buy a graphic card, to add on the mainboard in the
1 x PCI Express x16 (orange slot) for better performance.
A new graphic card, does also have the hdmi connector
This will be the cheapest way to repair it.
Good luck
My Msi G41 TM-P33 mainboard is cann't run probability. It run first step, but don't run if i save bios setting.
Hello download the manual here:
http://www.msi.com/product/mb/G41TM-P33.html#/?div=Manual
Please unzip the file, and adobe reader is needed to read the content.
Try to enter the bios, and load default settings.
Select the boot option for the drive.
First boot device: dvd drive.
Second the harddrive.
Save the settings you have made, and leave the bios.
Good luck
Ms 7529
Hello here are the supported cpu list for your mainboard:
http://www.msi.com/product/mb/G31M3-F-V2--3-Audio-Ports-.html#/?div=CPUSupport
You maybe have to upgrade the bios to support the new cpu.
1helpful
Please, I am need manual mother board MSI G31M3-L V2. Obrigado!
http://www.msi.com/service/download/manual-8486.html
then select US
see page 1 of pdf document.
INTRODUCTION
Thank you for choosing the G31M3 V2 Series (MS-7529 v1.x) Micro-ATX mainboard. The
G31M3 V2 Series are based on Intel
® G31 & Intel® ICH7 chipsets for optimal system
efficiency. Designed to fit the advanced Intel
® CoreTM 2 Duo/ CoreTM 2 Quad/ Pentium
Dual-Core E2XXX and Celeron 4XXX/ Wolfdale Series LGA 775 processor, the G31M3 V2
Series deliver a high performance and professional desktop platform solution.
1helpful
No DVI signal on G41TM-E43
Download the driver from here:
http://www.msi.com/product/mb/G41TM-E43.html#/?div=Driver&os=Win7%2064
Please select your windows system 32 or 64 bit.
Download the vga driver and unzip the file.
Uninstall the old one before you install the new.
Check also your bios for the graphic settings.
My advice is to buy a better graphic card to insert in the pci-e socket instead of using the onboard graphic for better performance.
Good luck
1helpful
G41tm-e43 + windows 7:
follow this link
New build turned on power no beeps no video nothing but fans
make sure that your little speaker is plugged in to the correct pins. This gets many people every time. If the speaker isn't plugged into the correct slot you're definitely not going to get anything to work...yeah i know...a silly speaker...you can have quite a few things plugged incorrectly and things will still work but if you have the speaker plugged into the wrong one...then ur dead in the water...find the little cylindrical speaker and try plugging it into a different slot...really look on that board for it. Should be labeled JFP2..connect the speaker to the 4 pin side of that 7 pin connection.
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
