SOURCE: All 4 stove burner coils only work partially
You should check electricity coming to the range. On the back of the range you will find small square cover which cover power cord connections. Be very careful not be shot by electricity. It should be 240V(between red and black wire) and 120V (between red and white and also black and white wire). If it is than you have a shortage or some broken wire inside the stove.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
SOURCE: Jennair model # JDS9865BDp
pull off your selector knob and shine a flashlight down the shaft, depending on your model, you may have the adjustable mmodel
at the bottom of the selector shaft, you may see a flat head screw adijudt it at ver small increments
i believ a 1/4 turn in should turn your flame down quite a bit
hope thsi helps
Testimonial: "tried adjusting the flame by turning the screw in the control knob shaft (very thin screwdriver used). It worked!!! Thanks for the help."
