LG MICROWAVE OVEN MODEL: LMV2053SB & SERIAL # 603 KMMC01299.
THE MICROWAVE OVEN JUST STOP WORKING AFTER HEATING UP VARIOUS FOODS? NO POWER NO SIGN OF TURNING ON THE POWER BACK?
WHAT SEEMS TO BE THE PROBLEMS? DOES THE OVEN HAVE FUSE?
SOURCE: Whirlpool microwave/oven model RM286PXV3
I have a 13yr old above-range oven which quit when my wife cooked food in an aluminized foil wrapper (a small fire ensued!). This oven has 3 thermal protection units, on the magnetron, the chassis and on top of the food cavity. This last one had failed open, and since it's in series with the magnetron thermal protection unit and the main relay, nothing would work. MAT electronics sell the units for less than $4, but my problem now is to pick one with the appropriate temperature cut-off. They range from 200 to 300F.
SOURCE: LG microwave oven
It's usually a bad door switch or a broken door switch mount. Once in a while it's due to a board problem. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: My LMV2053SB microwave won't turn on.
It is located on the top of the chassis under the outer cover.
You will need to remove the oven from the wall and remove the outer cover to get to it.
Having the installation instructions really helps in this case, but if for some reason you don't have yours, L.G. / Goldstar manuals can be downloaded here.
If yours' is not available there, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat
8-5 CT) and choose the appropriate prompt from the menu or visit here.
We have
the service manual and parts manual for this model and have uploaded them to our
site here and here to help you.
You will need the free
Acrobat Reader
to view or print it in case you don't have it
The oven cavity thermostat is part # 6930W1A003D and it can be ordered at the Sears
parts site.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Microwave oven coming on but not heating
I had the same problem with my Sharp OTR microwave/convection oven. I had 2 service reps out to look at it (Sears and Lowes) they both said it was the magnatron and would cost about $500.oo to repair it. I called Waverly's Appliance in Paris, TN and it turned out to be a diode. Total cost of repair was $35.00 including service call.
SOURCE: LG Microwave does not heat food
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode
and capacitors can br tested. The capacitor must bealloweddischarge
before testing, or you risk to get electrocuted, evenifpower is off.
Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
