Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
Posted on Jan 16, 2010
No remote to my sharp tv LC-32SB24U need codes to program my remote...
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1338
Points
I have a Sharp LC-32SB24U TV, I need the universal code for my universal remote.
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Remote control from Dish tv will not work volume on Coby 32" flat screen
This is not unusual--Dish and other remotes even if program will not have all the functions that may be needed---
I need a remote code for my vizio universal remote in order to set it up with this LC-32SB24U
Hi
Setup codes for Shart TV with Vizio universal remote control are:
0093, 0688
OK.
Iam on remote lockout,how do i get back in ? also how do i turn off the close caption? the tv is a sharp lc-32sb24u
Unplug your TV for 30 seconds then plug it back in , remote should work after that. Press CC button on your remote until you'll see CC OFF.
2helpful
Sharp LC-32SB24U TV. Remote no longer functions.
Unplu the TV from the wall, wait for 30 sec. plug it back in.
3helpful
Lost access to control SHARP TV
Unplug your unit and plug it back in after 2 minutes. When you plug it back in, try to use the remote to turn it on and see what happens. Good luck to you
I need to receive a manual on the operation of my sharp tv
I believe your TV is a LC-32SB24U, not LC-325B24U.
You can download a manual at www.sharp.ca/manuals
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
