Avanti sent me a new circuit board to replace that one that failed but they did not send instructions on where to solder the wires to the board. I can see where the red and black wires will go but am unsure of where the green and yellow wire is to be soldered. The board is a HYS60-12-KD V-0 130C. Any help you can provide will be greatly appreciated.
The colors of the wires were incorrectly stated on the last post. The red and black (power) wires were listed as red and white. The green and yellow wire was listed as two wires, green and white. It is actually only one wire that is green and yellow.
The green an yellow wire is a ground. Look for an area on the board with a ground symbol . Can you not match the location from the old board???
Either way the black and red are your positive and negative power, while the third is the ground. The wire probably are located in close proximity to each other.
Let me know if this helps
Jer
