My xbox 360 and my blu ray keep saying no signal on my onkyo tx-sr606, but my virgin media box is fine, any sollutions, all hdmi inputs have been tried
This unit has a defective hdmi board,this is a common problem with this model. The unit is to be taken to a onkyo service center for exchange of the hdmi board under warrenty, if out of warrentyit will cost you several hundards of dollars.
The problem is the hdmi board in the receiver .they are having trouble with the smd regulator and smd capactors that they are using on the board,they have updated the new boards as i have not got any back when replacing with the new boards. I have replaced at least 35 hdmi boards on this model. If you call Onkyo they will tell you that you have a hdmi board bad and take it to an onkyo dealer.
Assigning the Digital Input
If there’s no sound, you’ll need to assign the digital inputs as
necessary using the setup menus on the TX-SR606’s display.
If you connect your DVD player to the AV receiver’s COAXIAL 1
DIGITAL IN, and your cable/satellite receiver to the COAXIAL 2
DIGITAL IN, as shown, it’s not necessary to assign the digital input.
The onscreen setup menus appear only on a TV that is
connected to the HDMI OUT. If your TV is connected to the composite video or S-Video MONITOR OUT, or the
COMPONENT VIDEO OUT, use the TX-SR606’s display when changing settings.
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Overview:
I’m writing this report to provide insight into a common Okyo issue.When my Onkyo receiver began to malfunction my first response was to search the web for answers.What I fond was conflicting information. While all system issue may be unique, I hope this report shed some light on the subject.
System Breakdown: Receiver: Onkyo TX-SR606 7.1 Channel Home Theater Receiver (Black)
TV: Samsung - LN52A750 - 52" LCD TV - 1080p
Broadcast: Comcast
Component 1: XBOX 360 Elite
Component 2: PS3 120GB
Cables:Mediabridge Ultra Series - 10ft High Speed HDMI Cable - Version 1.3 Category 2 - 1080p - Blu-Ray - PS3 - W/ Nylon Sleeve Issue: When I first setup my Onkyo receiver it worked perfectly.Over time, my TV would display “Searching for Signal”.After about a few minutes the receiver would detect the XBOX 360 and work fine.At first it was no big deal until the problem progressed. The receiver began to take longer and longer to detect the signal from the XBOX 360.Finally it would take up to 30 minutes or would not detect a signal at all. Finally I went through the process of changing out the HDMI cables and switching ports.This did not work, so I call Onkyo.They walked me through a reset process that did not work.Finally they recommended that I take it to an approved Onkyo repair shop. Lucky for me there is a repair shop in the suburbs of Chicago about an hours drive from my location.There are not many approved Onkyo repair shops. Most people would have to ship their receiver to another state. I took the receiver to the repair shop.They seem to have a nice little scam going on… Here is the scam.. They tell you there is a 3 to 4 week wait time (or longer) until they can even look at your receiver! BUT, if you want to put it on the “Priority List” you can pay a $30 non refundable fee not covered by your warranty.Then you would only have to wait about a week.Tell me, who would not op for the priority list when your entire entertainment system is managed by the receiver?!?!?So I payed the $30.About 4 days later I get a call from the repairman.He says, all the HDMI ports work but they don’t have an XBOX 360 to hook it up to.So he can’t validate the problem.After arguing with him for an hour and listening to him cry about how crapy Onkyo receivers are and how hard the company is to work with, he agreed to do some research into the problem.I told him many times, simply look on the internet many people are having the same problem.Onkyo has to know something about this. Finally about a week later I get a call from the repair guy.He says he thinks he knows what the problem is.He has to order some capacitors and I could pay $45 for priority shipping.Umm wait one minute, I already paid $30 for priority service now you want me to pay more for shipping?No thank you!Over time I simply rewired my system to work without the receiver and to tell you the truth I almost forgot about the receiver.Finally I got a call from the repair shop about 2 months later saying I could come pick up my receiver.I talked to the repairman. He said the following… Solution: There are 4 capacitors that malfunction over time.It’s a common problem with Onkyo receivers. When the capacitors begin to malfunction you get intermittent signal response until it does not work. He could not explain why the cable still worked (everything was hooked up with HDMI cables). If you are experiencing this problem. I hope this helps save some time switching out cables and guessing why your system is not working. - Antious
HDMI has had a multitude of issues and yours is one of them. Your receiver has either 1.1,1.2,1.2a ver HDMI. If it's still under warranty, you can have it upgraded to 1.3b which is the current and working version. So far so good. If it's out of warranty, it's a 200-300 $ repair. If you just use HDMI directly to your TV, providing you have enough HDMI inputs on the set, you can just run optical or digital coaxial to the receiver and all will work fine. Hope this helps.
Hi, I have just completed this installation myself.
You are correct, HDMI to Amp Input from Bluray and then HDMI from Amp output to TV. Coloured cables are not required to operate the bluray now.
Good luck
HDMI switching is an ongoing problem for the 606. A number of people are having the same problem. Mine is at the local repair shop and Onkyo has told them the part is on backorder until April. I would look at another brand or upgrade to a higher leval Onkyo.
Hi there. for your receiver, the only time it can upconvert is when you go out as HDMI. In your current hookup (component out to tv) the signal from your cable (using a composite) will not be able to pass through the component cable. This means you either have to hook up your cable box using a component cable as well or add a composite cable (yellow) from monitor out of the receiver to the tv. Page 22 of the manual will show a diagram of the video signal flow. hope this helps.. ^_^
