Question about Toshiba TheaterWide 46HM94 46" Rear Projection HDTV
Hooking up a tv
We rented a toshiba theater wide hdtv. they said we could hook our dish network up to the vcr since we dont have hd dish network and hook the vcr up to the tv and our dish network will work well it doesnt do anything. we called them and they said they dont know what to do then if that dosent work. is there a way to hook it up from the vcr to the tv and it does work, if so how do i do it?
  • 4,102 Answers
Hi first of all are you using scart leads to plug into each device here is how it should be set up ok
1. Scart lead from dish network into vcr
2. then other scart from vcr into tv
3. Now ti recieve the signal from the dish network you need to have the telly on the right av channel so that its picking up the signal from the vcr.
you can test this by changing the channel on the vcr controll or direct via buttons on vcr.
If the channels change then your on the right av channel.
Now when your on right channel on telly you need to now make sure dish network is on and on a channel or press the tv guide button just so you know what your looking for when the picture comes through.
You need to press av on the vcr controll this will then pick up the signal from the dish network via the scart lead as av is the channel for scart lead.
say if you was recording from dish net to vcr you would put the vcr on av to pick up the signal so press av on vcr controll this should then allow you to watch the dish network with no problems.
Let me know if you still cant and ill assist you further if it dont work tell me what you have done so i know how much you have done ok
Posted on Feb 10, 2008
6ya staff
SOURCE:
I have dish network hd but hdmi does not work so i hooked it up direct whats the best one to put it on 1080pi or 480.480pi,720 or what
Hi my name is Mike Houston of DISH Network and I see youhave DISH Network HD the hdmi does not work. Depending on what the TV is set to;480, 480i, 720, 1080i will depend on what you have your receiver set to. Afteryou check your TV settings press the buttons of Menu-6-8 and it will take youto HDTV Setup. Make sure your TV settings match your DISH Network HD settings;if you have anymore questions please e-mail me at Michael.houston@dishnetwork.com.
Aug 31, 2011 | Hitachi 51F59 51" HDTV Projection...
Hooking VCR to DISH Network Reciever Box
In order to diagnose the problem I need your help.
Have you hooked the dish receiver directly into a tv or another device and had it working?
Have you tried a different cable at all?
Have you tried pressing the ant. button on the remote or tv/vcr button?
Please update me with as much info as possible and I will figure out where the problem is coming from. thanks
May 04, 2008 | Toshiba W627 VCR
We just bought a NS-PDP50HD-09 Insignia 50" plasma
Although we would not be able to assist you with power issue you're having with your TV, I can assure you that the issue with your new HD Insignia TV not turning on has nothing to do with the DISH Network receiver you have connected to it.
Phillip Chang
DISH Network Customer Service Representative
Feb 14, 2011 | Insignia 50 in. Flat-Panel Plasma HDTV
I have Dish network. I want to record TV onto the VCR, but cannot get channels to record. i can playback videotapes and the record works, but cannot figure out how to get the signal to record.
The output of the Dish Network box should be hooked to the input of the VCR.
The output of the VCR should be hooked to the input of the TV.
The VCR should be on channel 3 to record. Select channel to be recorded on the Dish Network box.
It sounds like you have Dish Network box output hooked to TV input.
& VCR output hooked to an aux. input on the TV.
Nov 28, 2010 | Quasar VHQ401 VHS VCR
CAn get audio but no video
On the top of your dish remote there are several buttons to control different devices..... pres the TV button to access the TV's menu. This should have been set up by the installer unless you did it your self..... Dish is very helpful with answers.....
Feb 14, 2010 | RCA RTD300 DVD/VCR Home Theatre System...
Hooking a Wii to Dish Network reciever(not a hd tv)
It sounds like you have a pretty new TV. This means that there should be multiple AV jacks in the back for setting up your many components. Plug in the receiver into #1, the Wii into #2, and any other equipment you may have (DVD, VCR etc.) in the same way. You should then use the original TV remote to switch between Video 1, 2, 3 and so one for each compnent you want to use. The button on the remote will be labeled video, tv/video, input select, or input, something like that.
Hope this helps!!
Dec 29, 2008 | RCA HD52W59 HDTV Projection Television
How do I hook up my Dish Satelite to it?
should go from your satellite to dish box might say sat on bck of box then the next [connection think says tv that should go to tv itsself or dvd vcr whatever ur hooking up to it then from that point hook it to ur tv
Oct 23, 2008 | JVC AV-56WP74 56" Rear Projection...
No Audio Out through the Optical OUT jack
just press the DVD button on the remote contol and you will be ok.. :)
Jun 16, 2008 | LG LHT734 System
First and foremost when the chance comes along buy a Harmony remote. Your spouse will love the simplification. A couple of things, On the tv with the optical hose connected and the other end in your hand, do you see the light. Its not a laser and eye safe. Should be a red glow. If not, implies two things the tvs optical is bad or it needs to be enabled via tv menu audio settings. If you see the red glow, then its a protocol issue. Verify your tv is setup on the proper audio mode that your receiver is wanting to see. Probably PCM. I am not directly farmiliar with the tv, but using the dish receiver as a reference (you know its working) set the audio options on the tv similar to the dish receiver. IE pcm, dts, etc.. Let me know thanks
Jun 16, 2008 | Zenith C34W23 34" TV
Toshiba TheaterWide 46HM94 46" Rear Projection HDTV Logo
176 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
