Samsung LN32A330J1N when powered on gets a quick picture then goes off. Every once in a while when on the picture will flash on then off again. Sound is always there. It's about a 1 1/2 years old. Suggestions?? Thanks
SAMSUNG BN44-00235B POWER SUPPLY Only $25 USD https://www.abctay.com/original-samsung-bn4400235b-power-supply-p-922.html
I have a LN32A330 with a cracked screen. I can sell you boards tha you may need or maybe i can purchase your non working set.
Please email me, [email protected]. You may need your power supply repaired. I am able to repair it for you if needed.
This can be one of two problems. The backlight inverter board is bad # BN44-00235B <or A $60-80
Or one of your backlights is bad/broken. Not a easy repair. Single lamp is about $16-25 whole kit $150. But finding a great tech who can or will take the screen/light box apart to do it will be the biggest task. Takes about 3 hrs to do. And if you do NOT know what you are doing,you will damage the screen.
Then you just throw it away. But if your lucky, it might just be a bad connection. If it comes one after it goes off. But if it just flashes on for a couple seconds then does not come back on, Most likely bad backlight/or inverter. It goes in to protection mode.I have seen in a couple of Sony's it being the T-con board "LCD control"board do the same. $60-125
I wish I could give you better news. It is not easy to tell the problem on that without testing out each lamp "15-20 of them w/a lamp tester" or checking out each transformer on the inverter board. Verry time consuming. This is why I push the Extended Warenty. LCD's still have bugs to weed out. Plasma's are even worse.
