Http://www.acer.com.ph/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3349&sp=page15e&ctx2.c2att1=210&miu10ekcond13.attN2B2F2EEF=3349&CountryISOCtxParam=PH&ctx1.att21k=1&CRC=1264622415
Above are the links direct to acer driver support and Download. You can download drivers for free both Windows XP, Windows Vista and Windows 7.
But first follow the procedure of Solution #1. Another way if you sound is working before and not yet formatted. You don't need to download a sound drivers.
Under the Device Manager >Sound> Type of Sound installed>, then right click and uninstall.
After you uninstalled, choose " Scan for Hardware Changes" ( The Blue TV images above) and it automatically installed you sound drivers
If you have any question feel free to visit my site : htt://www.impormasyon.info and write your comments
Hope this helps. Good luck, God bless
www.aiydriver.com
Pls tell me u use xp or vista
i sent u 2
driver for vista http://support.acer-euro.com/drivers/notebook/as_4720.html
there is for xp
http://www.laptopbeep.com/acer-aspire-4720z-windows-xp-drivers
Is your sound device driver properly installed? If not, you can download it here. Here's the link: http://www.acer.com.ph/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3349&sp=page15e&ctx2.c2att1=210&miu10ekcond13.attN2B2F2EEF=3349&CountryISOCtxParam=PH&ctx1.att21k=1&CRC=1264622415
To determine if your sound device driver is properly installed, navigate to your my computer's properties by typing devmgmt.msc at the run command and then click ok. In the Sound, video and game controllers, look for any question mark symbol which is color yellow, if it has, meaning your sound device driver is not installed. But if it is an exclamation point, meaning your sound device driver is corrupted. Install the driver for your sound device using the link above.
http://laptoprepairsecrets.blogspot.com/
SOURCE: problem with webcam..acer aspire 4720
i have acer aspire 4715z madel notebook.i instal vista but it didn't acept drive (wifi did not detect).so ppease send vista drive particularely wifi drive.
[email protected]
SOURCE: Acer Aspire 4720 PC Notebook doesn,t start in the evening hours
All drivers for Acer Aspire 4720Z model can be downloaded from ftp server of europe.acer.com site or from the link of acer.co.in
Due to resemblence of motherboard of Acer Travel Mate 6292, the drivers for this model & 4720Z are the same.
This information is given to me from Acer Service Centre .
you can sms them with serial no. along the problem. they will revert to u in 1 hr. 100% good service.
you can contact me at [email protected]
Acer SMS centre for cust care: 09901676677
Arun Kanojia
Pune
SOURCE: WiFi driver for Acer Laptop 4720 for Linux (Fedora version 8) free download
Try this link and see if it helps you locate the driver you need for linux. These are the Broadcom drivers, http://zh-tw.broadcom.com/support/ethernet_nic/netlink.php
SOURCE: acer aspire 4720 microphone problem
You can try these steps :
1. Goto Start >> Control Panel >> Sounds >> Recording.
2. Open the 'Microphone Properties' from the list of devices.
3. Change the status of 'Device Usage' to "Use this device (Enable)".
4. Apply settings and close the window.
5. If still the Microphones are not working, try to reinstall the Audio / Sound drivers. Restart your system.
please rate this advice if it helps.....tc! :)
