Question about KitchenAid KCMS1555RSS Stainless Steel Microwave Oven
Hi, my microwave is not heating and i cannot hear any humming sounds either. I replace a new magnetron already and it's the same. What else could it be? do you think I should replace the capacitor, diode and fuse too?
  • KitchenAid Master
  • 3,740 Answers
I would have started with the diode and capacitor (i.e the least expense) but you can check the diode by removing the input wire and doing a continuity check in BOTH directions. In other words check it then reverse the leads and check it again. It should only read in ONE direction. If it reads continuity in both directions or is open in both directions it is bad and must be replaced. If the diode check out fine then by all means check the capacitor. Just respect the fact it is a large capacitor and can really ruin your day if it is good and has a full charge. (Been there done that!) Take a screwdriver and ground across the terminals several times then note the position of the wires on the capacitor and remove the wires from ONE terminal set. Take your meter still on Ohms ( old simpson type dial meter for this test) and place it on the capacitors 2 terminals. Then rapidly reverse the leads and you should see a momentary jump on the meter then fall off. No jump when you repeatedly reverse the leads then the capacitor is bad. This should solve your problem unless there is a relay on the control board that controls the magnetron power.
Posted on Jan 16, 2010
  • KitchenAid Master
  • 1,300 Answers
Transformers usually go bad very often. You can check the capacitor with meter. Transformers are hard to check with meter. Usually have to have more than 1 Ohm of resistance. Check amp draw to see if it is consuming power.
GE microwave JE1660WB001 does not heat makes humming sound
The magnetron has gone and is the heart of the microwave oven, this part is the most expensive to replace, cheaper to buy new in the long run.
Apr 19, 2012 | GE JE1660 Microwave Oven
The microwave makes a loud "hum or buzz" noise but will not heat up the food My microwave is running and sounds like it is working but will not heat up anything.
Hi, Your hi-voltage system has gone bad. The noise you are hearing is the hi-voltage transformer. This has taken the magnetron which does the heating out. The magnetron has a 5 year warranty on it, the rest of these parts only have a year on them. Contact your nearest repair center. Thanks,
Jan 17, 2011 | Microwave Ovens
No heat in microwave. Makes loud humming sound when turn on. Model GE Spacemaker JVM166OWBC 04
The humming can be caused by a couple of bad parts. Usually it's the magnetron tube, the microwave source. They often fail by shorting out, and the loud hum from the power supply is what you hear. Another part called the HV diode may also have shorted, but the magnetron is more common.
A bad magnetron can be replaced, but it's a costly part. And microwave service should be left to a professional, because there are dangerous voltages under the cover and a chance of microwave leakage if repairs aren't done correctly. Between the part and labor costs, it might be more economical to replace the oven. Let a qualified servicer give you a repair estimate and then decide.
Jan 09, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave is making a loud humming noise when it is on and it isn't heating. It also has a burning smell. We had this microwave repaired replacing the magnetron and diode in Jan. 2006.
sounds like same problem again.... the magnetron is what does the heating and if the display is working and just humming sounds like the mag is not coming on .... could be the capacitor but most likely the magnetron again..... i am a appliance /heating and air company out of texas we work on these things everyday and is very common problem... thanks a/c and heating unlimited good luck
Dec 31, 2010 | Jenn-Air JMC7000 Microwave Oven
Timer functions, fan works, great humming noise, no heat. Magnetron??
If there is no heat at all, but you can hear the magnetron humming, it is probably bad. if there is uneven heat, the wave stirrer that distributes the microwaves around the cooking chamber may be bad. it will heat only one spot unless the wave stirrer is rotating.
Nov 20, 2010 | Maytag MMV5207 Microwave Oven
Microwave won't heat, light ,clock works the microwave just won't heat the items in it.
hELLO THERE
when a microwave quits heating but every thing else is ok normally
investigate these 4 areas
Investigate these three areas if your microwave won't heat but you hear a loud buzzing or humming noise:
microwave_diode.jpg Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
picturena.gif High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
microwave_magnetron.jpg Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Nov 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works but it doesn't heat up the food. What could it be?
The part that generates microwaves that heat the food is the magnetron. Typically when the magnetron fails, it shorts out. When that happens the oven will produce a loud buzzing or humming sound. It typically not worth the cost to replace the magnetron, because it is almost as much as buying a new oven.
Jul 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The unit is 3 years old and when I turn it on there is a loud hum. Theunit also does not heat but turns the turntable?
From your description it sounds like the magnetron has failed in this oven. That's the part the makes the microwaves to heat the food. It typically fails by shorting out and making a loud hum noise. It not usually worth fixing since the price of a replacement magnetron is almost as much as a new oven.
Jul 01, 2010 | GE Profile Spacemaker JVM1871 Microwave...
My microwave kenmore 66222500 makes a humming sound like if it was on when the door is closed. i have to unplugged it or leave door open to stop the humming sound. I tested the magnetron, the primary and...
Possibly a shorted relay on the main timer board?? hum coming from transformer being powered with no fan running. With No fan you can hear it hum. shorted power relay on main board.
Jul 28, 2017 | Kenmore 68361 Microwave Oven
Microwave does everything that it is supose to do just that it does not heat and the noise to heat increased. This happend yeaterday.
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Jul 30, 2009 | Goldstar MV-1526 Microwave Oven
KitchenAid KCMS1555RSS Stainless Steel Microwave Oven Logo
282 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
