Washing Machines Logo
Anonymous Posted on Jan 16, 2010
Machine won't Agitate
Machine fills, drains and spins, just won't agitate. I can pull forward on the knob a bit and it wil agitate until the next agitate cycle then I need to pull on the knob again to start the agitate.
knightheatin
Level 2:
  • Expert 149 Answers
  • Posted on Jan 16, 2010
knightheatin
Expert
Level 2:
Answers
149
Questions
0
Helped
34022
Points
376
Timer bad easy fix.
Testimonial: "Just as I had speculated. Thanks for the confirmation. I have replaced the timer and the machine is once again working wonderfully. 10 min to replace."
33helpful
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
The knob for my Kenmore 500 machine for water level broke off so I ordered a new one. I did take back off of washer and found out later I did not have to. Neighbor showed me how to take off top part of...
It's quite possible that when you released the console to replace the water level switch you disconnected the Lid Switch.
If the Lid Switch is disconnected the washer will likely not agitate, spin or drain and you won't hear the motor.
Check for a white plastic plug connected to the console and another connected to the cabinet.
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
10helpful
2answers
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
7helpful
2answers
No spin or agatae
Unplug machine. Change load type to medium. Clean door sensor. Set knob to drain and spin. Plug machine back in to powr. Open and close door 10 times in 15 seconds. Pull knob to activate drain and spin.
Frigidaire washer won't agitate
hi Cinebar.
this is what i found from the internet so not sure if this will be off help to you.
There could be several reasons why your Frigidaire washer will not agitate, including problems with the power supply, the wash cycle or the way in which the appliance was loaded. It is a good idea to try to resolve the problem with your washer yourself first since unnecessary repair call-outs can potentially be expensive if your appliance is outside its warranty period. Troubleshooting your Frigidaire washing machine will take about 15 minutes.
Confirm the water shutoff valves are open. If your Frigidaire washer cannot draw water from the pipes, it will not fill or agitate. The shutoff valves are usually located behind the washing machine where the water pipes meet the wall. Allow the washing machine to cool down for 30 minutes. Frigidaire appliances automatically shut off if the motor starts to overheat. The cool-down period lasts for half an hour if the appliance has not been switched off manually.
Verify that the detergent draw is tightly closed. If the dispenser is left open, the washer will not start or agitate its load. Push the draw so it sits flush with the front of the washing machine.
Ensure that the washing machine door is closed. As with the detergent door, the appliance will not start if the door is left slightly open, to prevent water from spilling onto the floor. Push the door closed until it clicks, and try your load again.
Confirm that your Frigidaire dryer is set to a spin cycle. If your dryer is set to a soak cycle or is currently in the soak portion of a longer cycle, it will not spin or agitate the wash. Make sure the appliance is set to a spin load and try again.
Contact Frigidaire if problems continue. You may be entitled to free service if your washing machine is within its warranty period. See Resources for Frigidaire's contact information.
or read up more at this link.
Frigidaire washer won agitate Google Search
Top Washing Machines Experts
john h
