You can format the SD card in your ViviCam 3785.
This utility formats the internal memory (or memory card) and erases all stored images and data. Make sure your SD card is in the unlocked position.
1. Press the button to turn on your ViviCam 3785.
2. Press the MODE button twice to enter Playback mode. Then press
the button to enter the Playback menu.
3. Select [Delete] by using the up/down arrow buttons, and press the OK button.
4. Select [Format ] by using the up/down arrow buttons, and press the OK button.
5. If you want to format your SD memory card or the internal memory choose
[OK] by pressing up/down arrow buttons, then press the OK button to confirm.
To cancel the action, select [Cancel] instead.
[No Image] pops up after the SD memory card or internal memory
has been formatted.
If you need a manual for your camera you can download a free PDF at
http://www.retrevo.com/support/Vivitar-3785-Digital-Cameras-manual/id/200ag818/t/2/
Please rate this solution. Thanks.
SOURCE: What is the max size of SD card that can be used
Any SD card will work in this camera. The largest capacity card is 2 GB. There are cards that look identical to SD cards that have much larger capacities, but these are SDHC (Secure Digital High Capacity) type cards - not SD cards; an will not work in your camera.
You can download your camera manual here:
SOURCE: can i use a 2 gig sd card in the vivicam 3785
Manual says that camera only supports up to 512MB. Just tried it with a 2GB card now--gives a "Card Full" error.
