We have a prestige remote starter I believe the number is APS620TX we cannot remember how to use the remote.
To start the vehicle, press and release the Key/Trunk button two times within 2 seconds.
IT SHOULD HAVE iCONS ON THE REMOTE( LITTLE PICTURES OF LOCK AND UNLOCK THATS LOCK AND UNLOCK AND RTHE LITTKLE CAR PRESS TWICE IN TEN SEC AND THAT SHOULD START THE ENGINE IF ITS PROGRAMED TO ALLOW REMOTE STARTING AND RUNNING FOR SOME PRE DETERMINED LEGENTH OF TIME. GO TO THE WWW.AUDIOVOX.COM WEB SITE AND DOWNLOAD THE MANUALS YOU NEED... HAVE FUN HOPE IT HELPS...
BATTERY REPLACEMENT
The transmitter incorporates a small LED visible through the case which is used to indicate battery
condition. You will notice a decrease in transmitter range as the battery condition deteriorates.
Transmitter battery replacement is recommended at least every 10 to 12 months, depending upon how
frequently the transmitter is used.
To replace the battery in the APS620TX:
1) Remove the small # 0 Phillips head screw from the rear of the case.
2) Remove the rear cover to access the discharged battery paying attention to the proper polarity
orientation.
3) Carefully remove and properly dispose of the discharged battery.
4) Insert the new battery, close the case, then reinstall the small case screw removed in step 1.
5) If you accidently dislodge the circuit board from the transmitter housing, be certain that the rubber
membrane is seated properly, and the buttons are properly exposed from the front view of the case,
then insert the circuit board, and return to step #4.
APS620TX Uses GP23 Battery
CAUTION: CARBON MONOXIDE GAS CAN CAUSE SERIOUS INJURY AND EVEN DEATH
It is the sole responsibility of the user to operate the vehicle this system is installed in a safe manner.
This device must not be used in an enclosed space like a garage, attached or detached, car port, or any
partially enclosed areas. Also this device must be placed in the service mode when dropping the vehicle
off for service to prevent injury to the service technician
These are the information about the battery replacement to your device. There is no other details given. Check the battery contacts inside the remote for any dirt or rust, which prevents the good contact for batter y terminals. If there is, clean it . OK.
