Master
- Posted on Feb 05, 2010
Re: When the model 41 comeson it makes a woolf...
If the burner mat is loose it will make that sound. A loose burner mat will also cause a soot problem. The soot can also be caused by too little air flow thru the burner.
Is it a toyostove laser 30 or a monitor 41? Hard to tell from your post, it says laser 30 in the title but model 41 in the question. If it is a monitor 41 the burner mat is probably loose. That will cause the sound you a hearing. Also check burner for carbon buildup. The soot usually indicates not enough fresh air getting to the burner.
