Philips Gemini CDJ-20 Top Loading Professional Compact Disc Drive CD Player Logo
Posted on Jan 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gemini CDJ02 - Pitch Control Slider Stuck @ 0% The Pitch Control Slider will pitch down all the way but sometimes it will randomly change pitch and most the time wont pitch-up past 0.1-0%. This happens on all settings with all cds. Anyone else had this happen?
deejaykrish
Level 2:
New Friend:
  • Expert 63 Answers
  • Posted on Jan 17, 2010
deejaykrish
Expert
Level 2:
New Friend:
Answers
63
Questions
Helped
28385
Points
107
Your pitch control is faulty or dry. Try spraying wd 40 into the pitch sliding hole form top to bottom. Dont over spray it. Just a bit from top to bottom will do. If issue still persists, then there's some capacitors are weak which controls this pitch.
Hi, There is a problem on my CDMP 6000 left player pitch control. When pitch control is switched on and adjusted to +/-, it does not get set at that value but keeps fluctuating. Also, the pitch control...
You MAY have contamination in the slider.You could try putting a little CRC226 into the slot and work the control. Use ONLY this product CRC226 available at Home Depot in the electrical dept/
My pitch slider has snaped off my cdj gemini 203's ? how do i fix it ?
The fader slider will have to be replaced. It is a bit of work, however finding the exact replacement often is hard unless you get it through the manufacturer.
The pitch slider suddenly wont go bellow 0.00, for
i had a similar problem i used a can of compressed air and sprayed the dust out from pitch control and it worked. the dust builds up static and interferes with signal> hope it helps
1helpful
2answers
Sound wavers (speeds up and slows down)
you need to replace the Pitch controls. I'm presuming it is a sliding pitch control. Use the Red start stop lights that reflect on the rotating wheel. put the pitch in center 0. does one row of the dots on the wheel stay completely still.now just turn it up op down a bit until it starts to move the dots slightly. now watch the dots now while there moving. Do they fluctuate they should be smoothe. do this on both decks to find out which one is fluctuating.
Gemini CDM3600 pitch slider
I am having same problem..anyone ?
Pitch Slider
You more than likely have to have the pitch control replaced or cleaned.
- OPTiC
Technics Repair Videos
Technics DJ Repair
DJ Equipment Sales
Technics Parts
Quartz accuracy not accurate
Sometimes it's down to the mains in the country you are in. Some decks change speed from 50HZ to 60HZ.
Gemini xl 500
on top of the pitch control there is a small hole, in this hole you can use a small screw driver  and turn it left and right to free any dirt inside this is the master pitch control
2helpful
2answers
Pitch control center moved
Hello, Mr. Dixon.
I had the same problem and i decided it whit this procedure:
1. Restoring Factory Default Settings
2. Set the PITCH Slider to the center ( 0 ) position.
3. With the CDX-05 in the start mode displaying “no Disk” hold down EJECT and TIME/ENTER and press FILTER. The TEMP display in the LCD reads 0.0 and the procedure is complete.
Peter Petrov
1helpful
2answers
Platter problem
THE PITCH slider or the variable resistor could have gone faulty. A new pitch is only $25 i think. They may need to salvage the pcb from your old one as technics no longer manufacters them. I've never seen the pitch led stay on lock when the actual pitch is not at zero. Hopefully the pitch did not short out the brake or the variable resistors on the motor's circuitboard.
keep me poted.
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
