I sounds like you have blown the woofer. open the unit and check. first disconnect the leads on the woffer, then use an ohm meeter. If you don't have an ohm meeter use a 9v battery across the speaker terminals. If you hear a thunk when the battery touches the terminals the speaker is okay. If tyou don't it's gone. If the ohm meeter reads some number like 4 to 9 the speaker would be okay. If it reads nothing or 000 then it's gone. If you need a speaker you can order it from Pro Line Music 215-736-8055
