Sony VAIO FRV37 Notebook Logo
Posted on Jan 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My problem is, i've had this computer for since 2003, I installed a new harddrive and it was wornking fine for about a year or so, then I think i got a virus so i reformated the harddrive but in the midle of doing it, the computer would get so hot that it would rebooth it sel and could not finish installing the recovery discs, so i went to my garage in the very cold weather amd iwas able to do it. my problem now is that when I put it to work it starts to overheat and goes to a blue screen momentarly, and reboots real fast once it.s almost finish the process starts all over and over again and again untill i disconect it and let it cool off then it will work for a few minutes again, is it the memory going bad or is the computer getting to old or what?
bob chang
Level 2:
Novelist:
Champion:
  • Expert 226 Answers
  • Posted on Mar 13, 2010
bob chang
Expert
Level 2:
Novelist:
Champion:
Answers
226
Questions
0
Helped
50929
Points
367
The CPU cooling fan on these things... that'd be my guess. It should come on within seconds of the system being turned on - and you should feel warm air blowing out of the main vents.
If the fan doesn't turn on right away, you'll get instant overheating - exactly what you've described.
Anonymous
Level 2:
Sergeant:
  • Expert 161 Answers
  • Posted on Jan 15, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
161
Questions
Helped
45397
Points
531
It have 2 reason
first u check to change another memory
last ur fans in ur cpu not work fine so can not heat relieving for ur cpu so when overheat it auto turn off
External harddrive not detected
if you think your HDD is broken take it out of the caddy and place in your PC if the new HDD pops up in my computer than your drive is fine simple buy a new caddy install and carry on
My external hd (fantom titanium) doesn't regularly open on my mac suddenly
fouad,
Inside the case of that Fantom is a regular harddrive.
Also inside that outer case is a small circuit board, that either the harddrive plugs directly into it; or there is an interface block the harddrive plugs into, and there are wires from it, that connect to the small circuit board.
(The USB cable is connected to the small circuit board)
It is this small circuit board that usually goes bad.
My suggestion is to remove the harddrive inside, purchase an economical external enclosure, and install the harddrive in it.
Have your harddrive back, and be able to use it as an external harddrive again also.
The Harddrive Inside:
Harddrives are measured by their Width.
A laptop harddrive is 2.5 inches across in width. (2-1/2 inches)
A desktop harddrive is 3.5 inches.
The Fantom Titanium II 500GB's harddrive inside, is 3.5 inches,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822204034
Details > Physical Spec > Form Factor > 3.5
What I can't tell you is whether it is an IDE (PATA) harddrive, or a SATA harddrive.
However this external enclosure for 3.5 inch harddrives, is for both IDE, (PATA), and SATA harddrives,
http://www.newegg.com/Product/Product.aspx?Item=N82E16817388014R
[ You can also look at the label on the harddrive, and look up it's model number online, to see if it is IDE or SATA. Just type the model number in your search bar ]
Just want to include information on IDE (PATA), and SATA, in case you are interested,
IDE: http://en.wikipedia.org/wiki/Parallel_ATA
SATA: http://en.wikipedia.org/wiki/Serial_ATA
Regards,
joecoolvette
1helpful
Hi. I've just purchased a computer but without the harddrive. I do have the o/s key but I'm not sure how to install the system without disks. Any help would be greatly appreciated!
You have to borrow or buy the install disks (Not the recovery disks), the problem is that not all keys work with all copies of the system.
I have a Gateway GT5654 desktop that won't stop shutting down. I bought the computer brand new about 3 years ago, and I've never had any problems until now (I've even been running Norton 360...
it is possible that one of the three are going out on the computer, motherboard, harddrive, power supply, only a computer tech could tell which one.
1helpful
I've replaced my corrupt harddrive, that was preinstralled with Vista, with another harddrive. I have product key on bottom of computer for OS. How can I reload system on new harddrive?
you need to contact the company you bought the computer from and ask them for the phone number to the software packege company they use with there computers if you contact them they will send you a copy of the vista install
My Acer crashed and now it is saying " NO Operating System found" as well as " Hard Disk Error"
Try finding the harddrive with Hirens boot cd > Norton partition magic.
I've you can find any partition or drive, your fine.
I've not your harddrive is dead.
Install XP professional over Windows 98, Big problem no un-locking Key
you have to reformat the hard from the xp cd when get to the part to delete partitons delete all partions then create a new partion then format to ntfs and most of the drives will come if not all if not you need to now the manufacture and model to get drives but reformat the harddrive first....
I have a Dell computer which came with microsoft works 2003 recently my harddrive went out and a friend installed a new one for me. I can't get microsoft works 2003 to come up. it doesn't even show on...
dear,
does cd show any files, if yes then it should install it..
if not then might be possible that there is scratches or brakage in cd...
if not, then it should be install ...
moreover, check if ur system has any previous files there,
what about backup. did ur friend put the backup to your new harddriver..
if yes, then remove any files existing relavant to that...and then reinstall a fresh copy..
hope it will work.
dont forget to rate, if its functional
regards,
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
